주요 콘텐츠로 건너뛰기
2017 Kia Niro Headlight Replacement
필요한 것
  1. 2017 Kia Niro Headlight Replacement, Headlight: 1 단계, 이미지 1/1
    • Open the hood of the vehicle and make sure it is secured to prevent injury.
  2. 2017 Kia Niro Headlight Replacement: 2 단계, 이미지 1/1
    • Locate the bulb cover cap which can be found under the hood and directly behind the headlight.
  3. 2017 Kia Niro Headlight Replacement: 3 단계, 이미지 1/1
    • Remove the bulb cover cap by rotating it counter-clockwise until it is fully detached.
  4. 2017 Kia Niro Headlight Replacement: 4 단계, 이미지 1/1
    • Place the cap in a location that is out of the way of your work area and where you can easily find it.
  5. 2017 Kia Niro Headlight Replacement: 5 단계, 이미지 1/1
    • Remove the old bulb by rotating counter-clockwise until it is detached, being careful not to drop the bulb into the hood of the vehicle.
  6. 2017 Kia Niro Headlight Replacement: 6 단계, 이미지 1/1
    • Prepare your replacement XtraVision Fog Light/Headlight Bulb 9005XV-2 for installation by removing it from the packaging and ensuring that the bulb is not broken.
  7. 2017 Kia Niro Headlight Replacement: 7 단계, 이미지 1/1
    • Insert the new bulb by pushing it into the bulb compartment.
    • Turn the bulb clockwise until it is secure.
  8. 2017 Kia Niro Headlight Replacement: 8 단계, 이미지 1/1
    • Reattach the cap you previously set aside by rotating clockwise until secure.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
Sydney Harper
회원 가입일: 10/23/20
229 평판
안내서 1개 작성함
Texas Tech, Team S9-G6, Cowan Fall 2020 Texas Tech, Team S9-G6, Cowan Fall 2020 회원
TTU-COWAN-F20S9G6
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 27
30일 전: 148
전체 시간: 3,767
