주요 콘텐츠로 건너뛰기
2017 Toyota 4Runner Key Fob Battery Replacement
필요한 것
  1. 2017 Toyota 4Runner Key Fob Battery Replacement, Key Fob Battery: 1 단계, 이미지 1/3 2017 Toyota 4Runner Key Fob Battery Replacement, Key Fob Battery: 1 단계, 이미지 2/3 2017 Toyota 4Runner Key Fob Battery Replacement, Key Fob Battery: 1 단계, 이미지 3/3
    • Push the side button on the key fob to release the real key from the fob.
  2. 2017 Toyota 4Runner Key Fob Battery Replacement: 2 단계, 이미지 1/3 2017 Toyota 4Runner Key Fob Battery Replacement: 2 단계, 이미지 2/3 2017 Toyota 4Runner Key Fob Battery Replacement: 2 단계, 이미지 3/3
    • Insert the key into the same shaped slit at the bottom of the key fob.
    • Twist the key to the right.
    • Separate the two halves of the key fob.
  3. 2017 Toyota 4Runner Key Fob Battery Replacement: 3 단계, 이미지 1/3 2017 Toyota 4Runner Key Fob Battery Replacement: 3 단계, 이미지 2/3 2017 Toyota 4Runner Key Fob Battery Replacement: 3 단계, 이미지 3/3
    • Remove the circuit board from the inside of the fob.
  4. 2017 Toyota 4Runner Key Fob Battery Replacement: 4 단계, 이미지 1/3 2017 Toyota 4Runner Key Fob Battery Replacement: 4 단계, 이미지 2/3 2017 Toyota 4Runner Key Fob Battery Replacement: 4 단계, 이미지 3/3
    • Remove the battery gently with a nylon spudger.
    • Make sure you don't damage any of the three tabs that hold the battery in place.
  5. 2017 Toyota 4Runner Key Fob Battery Replacement: 5 단계, 이미지 1/3 2017 Toyota 4Runner Key Fob Battery Replacement: 5 단계, 이미지 2/3 2017 Toyota 4Runner Key Fob Battery Replacement: 5 단계, 이미지 3/3
    • Place a new battery gently back into the circuit board with the positive side of the battery facing up.
    • Make sure the tabs click into place.
  6. 2017 Toyota 4Runner Key Fob Battery Replacement: 6 단계, 이미지 1/3 2017 Toyota 4Runner Key Fob Battery Replacement: 6 단계, 이미지 2/3 2017 Toyota 4Runner Key Fob Battery Replacement: 6 단계, 이미지 3/3
    • Align the circuit board with the base of the fob case and gently press it back into place.
  7. 2017 Toyota 4Runner Key Fob Battery Replacement: 7 단계, 이미지 1/3 2017 Toyota 4Runner Key Fob Battery Replacement: 7 단계, 이미지 2/3 2017 Toyota 4Runner Key Fob Battery Replacement: 7 단계, 이미지 3/3
    • Align the top and base of the fob and snap it back into place.
  8. 2017 Toyota 4Runner Key Fob Battery Replacement: 8 단계, 이미지 1/3 2017 Toyota 4Runner Key Fob Battery Replacement: 8 단계, 이미지 2/3 2017 Toyota 4Runner Key Fob Battery Replacement: 8 단계, 이미지 3/3
    • Insert the key back into the fob.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Nic
회원 가입일: 01/18/22
181 평판
안내서 1개 작성함
York University, Team 1-19, O'Regan Winter 2022 York University, Team 1-19, O'Regan Winter 2022 회원
YORK-O'REGAN-W22S1G19
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 16
30일 전: 66
전체 시간: 2,332
