주요 콘텐츠로 건너뛰기
2018-Present Toyota Corolla Cabin Air Filter Replacement
  1. 2018-Present Toyota Corolla Cabin Air Filter Replacement, Cabin Air Filter: 1 단계, 이미지 1/3 2018-Present Toyota Corolla Cabin Air Filter Replacement, Cabin Air Filter: 1 단계, 이미지 2/3 2018-Present Toyota Corolla Cabin Air Filter Replacement, Cabin Air Filter: 1 단계, 이미지 3/3
    • Open Glove compartment located on the passenger side of the vehicle.
    • Pull the plastic lever to the right to detach from glove compartment hook.
  2. 2018-Present Toyota Corolla Cabin Air Filter Replacement: 2 단계, 이미지 1/3 2018-Present Toyota Corolla Cabin Air Filter Replacement: 2 단계, 이미지 2/3 2018-Present Toyota Corolla Cabin Air Filter Replacement: 2 단계, 이미지 3/3
    • Remove each hook on the sides of the glove compartment one at a time.
    • Then, using two hands you can fully pull down the glove compartment door.
  3. 2018-Present Toyota Corolla Cabin Air Filter Replacement: 3 단계, 이미지 1/3 2018-Present Toyota Corolla Cabin Air Filter Replacement: 3 단계, 이미지 2/3 2018-Present Toyota Corolla Cabin Air Filter Replacement: 3 단계, 이미지 3/3
    • Open and remove plastic lid to access filter.
  4. 2018-Present Toyota Corolla Cabin Air Filter Replacement: 4 단계, 이미지 1/3 2018-Present Toyota Corolla Cabin Air Filter Replacement: 4 단계, 이미지 2/3 2018-Present Toyota Corolla Cabin Air Filter Replacement: 4 단계, 이미지 3/3
    • Pull old filter completely out from compartment.
    • Then, you can slide the brand-new filter right in.
  5. 2018-Present Toyota Corolla Cabin Air Filter Replacement: 5 단계, 이미지 1/3 2018-Present Toyota Corolla Cabin Air Filter Replacement: 5 단계, 이미지 2/3 2018-Present Toyota Corolla Cabin Air Filter Replacement: 5 단계, 이미지 3/3
    • Place the lid back on, snapping into place.
    • Push the sides of the glove compartment to get the side handles back in place.
    • Clip plastic leaver back on to hook.
결론
Desiray Huerta
회원 가입일: 09/20/23
121 평판
안내서 1개 작성함
Austin Community College, Team 22-5, Watkins Fall 2023 Austin Community College, Team 22-5, Watkins Fall 2023 회원
AUSTINCC-WATKINS-F23S22G5
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 35
30일 전: 186
전체 시간: 1,037
