주요 콘텐츠로 건너뛰기
2018-Present Toyota Corolla Tail Light Bulb Replacement
필요한 것
  1. 2018-Present Toyota Corolla Tail Light Bulb Replacement, Tail Light Bulb: 1 단계, 이미지 1/3 2018-Present Toyota Corolla Tail Light Bulb Replacement, Tail Light Bulb: 1 단계, 이미지 2/3 2018-Present Toyota Corolla Tail Light Bulb Replacement, Tail Light Bulb: 1 단계, 이미지 3/3
    • The plastic protective cover is held in place by one retention clip at the top and one retention clip at the bottom.
    • Gently use a small pry bar or screw driver to loosen the cover.
  2. 2018-Present Toyota Corolla Tail Light Bulb Replacement: 2 단계, 이미지 1/2 2018-Present Toyota Corolla Tail Light Bulb Replacement: 2 단계, 이미지 2/2
    • Locate the two 10mm bolts that secure the bulb housing in place.
    • Using a socket wrench, extension, and 10mm socket, remove both bolts.
  3. 2018-Present Toyota Corolla Tail Light Bulb Replacement: 3 단계, 이미지 1/2 2018-Present Toyota Corolla Tail Light Bulb Replacement: 3 단계, 이미지 2/2
    • Remove the bulb housing by pulling directly back from the vehicle.
    • To overcome the retention system, you may use the small pry bar or screwdriver to gently apply force between the bulb housing and vehicle.
  4. 2018-Present Toyota Corolla Tail Light Bulb Replacement: 4 단계, 이미지 1/1
    • Twist counter clockwise to loosen the tail light bulb receptacle.
    • In the picture, the two triangles are used to indicate if the housing is loose (triangles not matched up) or tightened (triangles matched up).
  5. 2018-Present Toyota Corolla Tail Light Bulb Replacement: 5 단계, 이미지 1/1
    • Pull the bulb receptacle out of the bulb housing.
    • This should not be forced. If resistance is met, the socket may not be turned counter clockwise completely.
  6. 2018-Present Toyota Corolla Tail Light Bulb Replacement: 6 단계, 이미지 1/1
    • Remove the non-functioning light bulb by pulling it from the bulb socket.
    • Bulb is held in place by retention clips and may require gently working the bulb back and forth while pulling.
    • Insert the replacement bulb into the socket.
결론
Don't forget to verify the new bulb is working before reassembling. To reassemble your device, follow these instructions in reverse order. The replacement of the bulb on the last step represents the apex of the repair process and following the steps in reverse order will return the tail light to full functionality.
Cecil Mrstik
회원 가입일: 02/20/24
133 평판
안내서 1개 작성함
University of Arizona, Team 3-2, Cools Stephens Spring 2024 University of Arizona, Team 3-2, Cools Stephens Spring 2024 회원
ARIZONA-COOLS STEPHENS-S24S3G2
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 25
30일 전: 95
전체 시간: 230
