주요 콘텐츠로 건너뛰기
2018-2022 Honda Accord Cabin Filter Replacement
  1. 2018-2022 Honda Accord Cabin Filter Replacement, Cabin Filter: 1 단계, 이미지 1/1
    • Open your glovebox.
  2. 2018-2022 Honda Accord Cabin Filter Replacement: 2 단계, 이미지 1/2 2018-2022 Honda Accord Cabin Filter Replacement: 2 단계, 이미지 2/2
    • Remove the latch by pulling it down and outward.
  3. 2018-2022 Honda Accord Cabin Filter Replacement: 3 단계, 이미지 1/1
    • Simultanously pull in and toward you on both edges (preferably farthest away from you) to dislodge the dash compartment.
    • Although I am using one hand because I am taking a picture of my phone, the same would be done to the other side.
  4. 2018-2022 Honda Accord Cabin Filter Replacement: 4 단계, 이미지 1/3 2018-2022 Honda Accord Cabin Filter Replacement: 4 단계, 이미지 2/3 2018-2022 Honda Accord Cabin Filter Replacement: 4 단계, 이미지 3/3
    • To remove the cap, pull the small levers simultaneously on both sides, and then pull towards you.
    • Again, please note the same is done to the other side.
  5. 2018-2022 Honda Accord Cabin Filter Replacement: 5 단계, 이미지 1/2 2018-2022 Honda Accord Cabin Filter Replacement: 5 단계, 이미지 2/2
    • Remove the old cabin filter by pulling it towards you.
    • Replace both filter and filter cap with respect of arrows pointing down.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
lxndr
회원 가입일: 06/25/23
121 평판
안내서 1개 작성함
Austin Community College, Team 7-5, Watkins Summer 2023 Austin Community College, Team 7-5, Watkins Summer 2023 회원
AUSTINCC-WATKINS-SU23S7G5
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 15
30일 전: 80
전체 시간: 462
