주요 콘텐츠로 건너뛰기
2018 Chevrolet Equinox Cabin Air Filter Replacement
필요한 것
  1. 2018 Chevrolet Equinox Cabin Air Filter Replacement, Cabin Air Filter: 1 단계, 이미지 1/2 2018 Chevrolet Equinox Cabin Air Filter Replacement, Cabin Air Filter: 1 단계, 이미지 2/2
    • Turn off vehicle air.
    • Find the glove box on the passenger side of the vehicle.
    • Open and remove all items from the glove box.
  2. 2018 Chevrolet Equinox Cabin Air Filter Replacement: 2 단계, 이미지 1/3 2018 Chevrolet Equinox Cabin Air Filter Replacement: 2 단계, 이미지 2/3 2018 Chevrolet Equinox Cabin Air Filter Replacement: 2 단계, 이미지 3/3
    • You will see a latch on the right side of the glove box.
    • Unhook the latch by gently pulling the latch outwards from the glove box.
  3. 2018 Chevrolet Equinox Cabin Air Filter Replacement: 3 단계, 이미지 1/2 2018 Chevrolet Equinox Cabin Air Filter Replacement: 3 단계, 이미지 2/2
    • Place your hands on the sides of the glove box.
    • Tightly squeeze the sides inward, and pull the glove box forward to detach the glove box from the dashboard.
  4. 2018 Chevrolet Equinox Cabin Air Filter Replacement: 4 단계, 이미지 1/3 2018 Chevrolet Equinox Cabin Air Filter Replacement: 4 단계, 이미지 2/3 2018 Chevrolet Equinox Cabin Air Filter Replacement: 4 단계, 이미지 3/3
    • The cabin air filter box has one 7/32" screw on each side.
    • Use a 7/32" nut driver to remove these two screws.
  5. 2018 Chevrolet Equinox Cabin Air Filter Replacement: 5 단계, 이미지 1/3 2018 Chevrolet Equinox Cabin Air Filter Replacement: 5 단계, 이미지 2/3 2018 Chevrolet Equinox Cabin Air Filter Replacement: 5 단계, 이미지 3/3
    • Plastic tabs will be right beneath the screws highlighted by markups.
    • Push the tabs in on both sides of the box simultaneously.
    • Lift the lid of the box to find the old cabin air filter.
  6. 2018 Chevrolet Equinox Cabin Air Filter Replacement: 6 단계, 이미지 1/3 2018 Chevrolet Equinox Cabin Air Filter Replacement: 6 단계, 이미지 2/3 2018 Chevrolet Equinox Cabin Air Filter Replacement: 6 단계, 이미지 3/3
    • Remove the filter, and check for debris in the filter box.
  7. 2018 Chevrolet Equinox Cabin Air Filter Replacement: 7 단계, 이미지 1/3 2018 Chevrolet Equinox Cabin Air Filter Replacement: 7 단계, 이미지 2/3 2018 Chevrolet Equinox Cabin Air Filter Replacement: 7 단계, 이미지 3/3
    • Place the new filter in the filter box.
    • The filter has an arrow, as indicated by the red box. Ensure that the arrow points down when placing the filter.
  8. 2018 Chevrolet Equinox Cabin Air Filter Replacement: 8 단계, 이미지 1/1
    • Pull the lid down and press both sides to close the filter box.
    • If you hear a clicking sound, then it means that the lid is closed.
결론
To reassemble your glovebox, follow these instructions in reverse order.
Allan
회원 가입일: 06/08/22
157 평판
안내서 1개 작성함
University of Memphis, Team 1-2, Lane Summer 2022 University of Memphis, Team 1-2, Lane Summer 2022 회원
UM-LANE-SU22S1G2
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 28
30일 전: 119
전체 시간: 2,704
