주요 콘텐츠로 건너뛰기
2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement
필요한 것
  1. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement, Gasket Replacement: 1 단계, 이미지 1/2 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement, Gasket Replacement: 1 단계, 이미지 2/2
    • Pop the hood and remove the plastic battery cover.
  2. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: 2 단계, 이미지 1/1
    • Using a 1/4 inch flex head ratchet and a 1/4 inch shallow 10mm socket, loosen the battery cable tightening nut.
  3. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: 3 단계, 이미지 1/1
    • Remove the vacuum line from the front of the intake by gently pulling up on the line releasing it from the clamps.
  4. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: 4 단계, 이미지 1/1
    • Disconnect the MAP sensor.
  5. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: 5 단계, 이미지 1/2 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: 5 단계, 이미지 2/2
    • Using a 1/4 inch 7mm deep socket and 1/4 inch flex head wrench, loosen the worm clamp on the cold air intercooler pipe.
  6. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: 6 단계, 이미지 1/2 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: 6 단계, 이미지 2/2
    • Using a 1/4 inch 10mm wobbly socket, 1/4 inch 8 inch extension, and 1/4 inch ratchet, remove all 5 of the cap screws holding the intake to the cylinder head.
  7. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: 7 단계, 이미지 1/1
    • Remove the intake out of the engine bay by lifting and pulling the intake towards you.
  8. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: 8 단계, 이미지 1/2 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: 8 단계, 이미지 2/2
    • Unplug both left and right engine ground strap connections.
  9. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: 9 단계, 이미지 1/1
    • Using a 1/4 inch 8mm deep socket, remove the 8 PCV plate mounting bolts.
  10. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: 10 단계, 이미지 1/1
    • Remove the PCV plate and the old PCV plate gasket.
  11. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: 11 단계, 이미지 1/1
    • Wipe down the mounting surface and the inside of the PCV plate with a shop rag.
  12. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: 12 단계, 이미지 1/1
    • Install the new PCV plate gasket.
  13. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: 13 단계, 이미지 1/2 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: 13 단계, 이미지 2/2
    • Reinstall the PCV plate on the side of the engine block.
    • Torque the PCV plate mounting bolts to 89 inch pounds.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Ryen Pilialoha
회원 가입일: 04/09/19
307 평판
안내서 1개 작성함
댓글 2개
Can this be the p04DB code that came up on my car??
Angelo - 답글
Would this fix the code p04DB
Angelo - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 31
30일 전: 181
전체 시간: 4,987
