주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2018 Jeep Compass Key Fob Battery Replacement
필요한 것
  1. 2018 Jeep Compass Key Fob Battery Replacement, Key Fob Battery: 1 단계, 이미지 1개 중 1개
    • Remove the valet key from the top by sliding the button over.
    • You can not open the FOB without removing the valet key.
  2. 2018 Jeep Compass Key Fob Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Use an opening tool or flathead screwdriver to separate the top and bottom of the key fob.
  3. 2018 Jeep Compass Key Fob Battery Replacement: 3 단계, 이미지 3개 중 1개 2018 Jeep Compass Key Fob Battery Replacement: 3 단계, 이미지 3개 중 2개 2018 Jeep Compass Key Fob Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Use a spudger or pair of tweezers to pull the battery out.
    • Take care not to puncture the battery.
    • You can grab the battery with you fingers once the tweezers raise it out of the battery clasp.
  4. 2018 Jeep Compass Key Fob Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Replace the new battery in the battery holder.
    • Make sure that the battery is inserted correctly with positive(+) and negative(-) terminals corresponding with the symbols on the device, or the key fob will not work.
  5. 2018 Jeep Compass Key Fob Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Align the two halves of the fob and press them together with your fingers until they snap into place.
  6. 2018 Jeep Compass Key Fob Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Replace the valet key at the top.
결론
  • Make sure that the new battery is clasped in.
  • Snap the sides back together.
  • Insert the valet key back into its slot.
  • Test the key fob on your vehicle to ensure it works perfectly.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Christi Esparza
회원 가입일: 06/15/25
154 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 14
지난 30일: 54
전체 시간: 559
