주요 콘텐츠로 건너뛰기
2018 Toyota Corolla LE Battery Replacement
필요한 것
  1. 2018 Toyota Corolla LE Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Caution: Wear gloves and a mask as a basic safety precaution to avoid inhaling or touching toxins which may be harmful to your lungs.
    • Car batteries have a voltage comparable to small Duracell batteries; don't work in fear of being shocked.
    • Open the hood and locate your battery.
  2. 2018 Toyota Corolla LE Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the screws from the brace securing the battery.
  3. 2018 Toyota Corolla LE Battery Replacement: 3 단계, 이미지 3개 중 1개 2018 Toyota Corolla LE Battery Replacement: 3 단계, 이미지 3개 중 2개 2018 Toyota Corolla LE Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Disconnect the connector on the right with no coloring or cap.
    • Remove the vertically facing screw to disconnect the battery.
    • Loosen the clamp on the side directly connected to the battery.
    • Move both away from the battery once they've been disconnected/loosened enough to disconnect.
  4. 2018 Toyota Corolla LE Battery Replacement: 4 단계, 이미지 3개 중 1개 2018 Toyota Corolla LE Battery Replacement: 4 단계, 이미지 3개 중 2개 2018 Toyota Corolla LE Battery Replacement: 4 단계, 이미지 3개 중 3개
    • After removing the red cap on the second connector follow the same process you did with the right.
    • Remove the vertical screw first.
    • Loosen the horizontal screw on the side in order to fully free the battery.
  5. 2018 Toyota Corolla LE Battery Replacement: 5 단계, 이미지 3개 중 1개 2018 Toyota Corolla LE Battery Replacement: 5 단계, 이미지 3개 중 2개 2018 Toyota Corolla LE Battery Replacement: 5 단계, 이미지 3개 중 3개
    • Car batteries are quite heavy so get ready to give a good lift.
    • Ensure you have a good grip on both ends and pull up both sides at once; you don't want the battery to tilt to one side
  6. 2018 Toyota Corolla LE Battery Replacement: 6 단계, 이미지 2개 중 1개 2018 Toyota Corolla LE Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Pull out the tray that was holding the battery.
    • Clean off any dust or corrosion formed from use.
    • Place it back using the points on it to indicate how to fit it back in.
결론
작성자
2다른 기여자 명과 함께
Moses Pa
회원 가입일: 09/19/23
133 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 42
지난 30일: 213
전체 시간: 1,525
