주요 콘텐츠로 건너뛰기
2018-Present Toyota Corolla Engine Air Filter Replacement
필요한 것
  1. 2018-Present Toyota Corolla Engine Air Filter Replacement, Engine Air Filter: 1 단계, 이미지 1/2 2018-Present Toyota Corolla Engine Air Filter Replacement, Engine Air Filter: 1 단계, 이미지 2/2
    • Park your Toyota corolla on a flat surface. Turn off engine. Remove keys from ignition.
    • Open the hood after the engine is cool.
  2. 2018-Present Toyota Corolla Engine Air Filter Replacement: 2 단계, 이미지 1/3 2018-Present Toyota Corolla Engine Air Filter Replacement: 2 단계, 이미지 2/3 2018-Present Toyota Corolla Engine Air Filter Replacement: 2 단계, 이미지 3/3
    • Lift and secure the hood.
  3. 2018-Present Toyota Corolla Engine Air Filter Replacement: 3 단계, 이미지 1/3 2018-Present Toyota Corolla Engine Air Filter Replacement: 3 단계, 이미지 2/3 2018-Present Toyota Corolla Engine Air Filter Replacement: 3 단계, 이미지 3/3
    • Unclip the housing clip to open the housing.
  4. 2018-Present Toyota Corolla Engine Air Filter Replacement: 4 단계, 이미지 1/3 2018-Present Toyota Corolla Engine Air Filter Replacement: 4 단계, 이미지 2/3 2018-Present Toyota Corolla Engine Air Filter Replacement: 4 단계, 이미지 3/3
    • Unclip the housing's second clip on the other side of the housing.
  5. 2018-Present Toyota Corolla Engine Air Filter Replacement: 5 단계, 이미지 1/2 2018-Present Toyota Corolla Engine Air Filter Replacement: 5 단계, 이미지 2/2
    • Lift the housing.
  6. 2018-Present Toyota Corolla Engine Air Filter Replacement: 6 단계, 이미지 1/2 2018-Present Toyota Corolla Engine Air Filter Replacement: 6 단계, 이미지 2/2
    • Remove the old air filter by gently taking the filter out from under the housing.
  7. 2018-Present Toyota Corolla Engine Air Filter Replacement: 7 단계, 이미지 1/2 2018-Present Toyota Corolla Engine Air Filter Replacement: 7 단계, 이미지 2/2
    • Install the new air filter by placing it into the housing.
    • Check to make sure it is properly oriented with the rubber rim facing up.
  8. 2018-Present Toyota Corolla Engine Air Filter Replacement: 8 단계, 이미지 1/2 2018-Present Toyota Corolla Engine Air Filter Replacement: 8 단계, 이미지 2/2
    • Close the housing.
  9. 2018-Present Toyota Corolla Engine Air Filter Replacement: 9 단계, 이미지 1/3 2018-Present Toyota Corolla Engine Air Filter Replacement: 9 단계, 이미지 2/3 2018-Present Toyota Corolla Engine Air Filter Replacement: 9 단계, 이미지 3/3
    • Resecure the clips on both sides of the housing.
결론
Final Checks:
  • Check to ensure that the housing is clipped securely in its place.
  • Start your vehicle to ensure that it is running smoothly.
  • Check dashboard to ensure there is no warning light flashing.
다른 한 분이 해당 안내서를 완성하였습니다.
Quoc Nguyen
회원 가입일: 02/02/24
169 평판
안내서 1개 작성함
UC Davis, Team 2-7, Andersen Winter 2024 UC Davis, Team 2-7, Andersen Winter 2024 회원
UCD-ANDERSEN-W24S2G7
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 21
30일 전: 85
전체 시간: 283
