주요 콘텐츠로 건너뛰기
2019 Honda Civic Spark Plugs Replacement
필요한 것
  1. 2019 Honda Civic Spark Plugs Replacement, Spark Plugs: 1 단계, 이미지 1/2 2019 Honda Civic Spark Plugs Replacement, Spark Plugs: 1 단계, 이미지 2/2
    • Use a wrench to remove the bolts on the top of the engine cover.
    • Remove the engine cover.
  2. 2019 Honda Civic Spark Plugs Replacement: 2 단계, 이미지 1/3 2019 Honda Civic Spark Plugs Replacement: 2 단계, 이미지 2/3 2019 Honda Civic Spark Plugs Replacement: 2 단계, 이미지 3/3
    • Detach the clamps of the wire holder to disconnect it.
    • Put a screwdriver under the small panel on the wire connector and lift the panel.
    • Separate the cable from the wire connector.
  3. 2019 Honda Civic Spark Plugs Replacement: 3 단계, 이미지 1/2 2019 Honda Civic Spark Plugs Replacement: 3 단계, 이미지 2/2
    • Use the wrench to remove the bolt that is placed beside the wire connector.
    • Simply pull out the connector.
  4. 2019 Honda Civic Spark Plugs Replacement: 4 단계, 이미지 1/3 2019 Honda Civic Spark Plugs Replacement: 4 단계, 이미지 2/3 2019 Honda Civic Spark Plugs Replacement: 4 단계, 이미지 3/3
    • Make sure the spark plug area is dry before removing the spark plug.
    • Attach the socket to the socket wrench.
    • Put the socket inside the cylinder head and twist the socket wrench to remove the spark plug.
  5. 2019 Honda Civic Spark Plugs Replacement: 5 단계, 이미지 1/1
    • Inspect the new spark plug to ensure that it is completely dry.
  6. 2019 Honda Civic Spark Plugs Replacement: 6 단계, 이미지 1/2 2019 Honda Civic Spark Plugs Replacement: 6 단계, 이미지 2/2
    • Remove the old spark plug and attach the new spark plug to the socket.
    • Place the socket back in the cylinder head and twist the socket wrench to install the spark plug.
  7. 2019 Honda Civic Spark Plugs Replacement: 7 단계, 이미지 1/1
    • Connect the wire back to the spark plug.
  8. 2019 Honda Civic Spark Plugs Replacement: 8 단계, 이미지 1/1
    • Place the engine cover over the engine and reinstall the bolts using the wrench.
결승점
다른 4명이 해당 안내서를 완성하였습니다.
Bouttia Oshrieh
회원 가입일: 07/07/20
265 평판
안내서 1개 작성함
York University, Team S1-G19, Allen Summer 2020 York University, Team S1-G19, Allen Summer 2020 회원
YORK-ALLEN-SU20S1G19
1 회원
안내서 1개 작성하였습니다
댓글 한 개
Very informative.
Anwar Kazmi - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 38
30일 전: 243
전체 시간: 8,938
