주요 콘텐츠로 건너뛰기
2016-2022 Honda HR-V Rear Signal Light Bulb Replacement
필요한 것
  1. 2016-2022 Honda HR-V Rear Signal Light Bulb Replacement, Rear Signal Light Bulb: 1 단계, 이미지 1개 중 1개
    • Press the tailgate release button and lift open the rear hatch.
  2. 2016-2022 Honda HR-V Rear Signal Light Bulb Replacement: 2 단계, 이미지 3개 중 1개 2016-2022 Honda HR-V Rear Signal Light Bulb Replacement: 2 단계, 이미지 3개 중 2개 2016-2022 Honda HR-V Rear Signal Light Bulb Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the two screws beside each tail light assembly (four total) using a Phillips #1 screwdriver.
  3. 2016-2022 Honda HR-V Rear Signal Light Bulb Replacement: 3 단계, 이미지 2개 중 1개 2016-2022 Honda HR-V Rear Signal Light Bulb Replacement: 3 단계, 이미지 2개 중 2개
    • Place both hands on the tail light assembly and pull it directly outwards (away from the vehicle).
    • The tail light assembly will still be connected to the vehicle by wiring, so make sure to be careful when pulling the light assembly out.
  4. 2016-2022 Honda HR-V Rear Signal Light Bulb Replacement: 4 단계, 이미지 3개 중 1개 2016-2022 Honda HR-V Rear Signal Light Bulb Replacement: 4 단계, 이미지 3개 중 2개 2016-2022 Honda HR-V Rear Signal Light Bulb Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the rear signal light bulb from the light assembly by rotating the bulb socket counterclockwise.
  5. 2016-2022 Honda HR-V Rear Signal Light Bulb Replacement: 5 단계, 이미지 2개 중 1개 2016-2022 Honda HR-V Rear Signal Light Bulb Replacement: 5 단계, 이미지 2개 중 2개
    • Pull apart the light bulb from its socket.
    • Replace with a new light bulb and apply pressure to ensure the light bulb is securely fastened.
  6. 2016-2022 Honda HR-V Rear Signal Light Bulb Replacement: 6 단계, 이미지 3개 중 1개 2016-2022 Honda HR-V Rear Signal Light Bulb Replacement: 6 단계, 이미지 3개 중 2개 2016-2022 Honda HR-V Rear Signal Light Bulb Replacement: 6 단계, 이미지 3개 중 3개
    • Slide the light assembly into the raised white plastic attached to the vehicle.
    • Align the holes on the light assembly to the holes on the vehicle and fasten the bolts into position.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Guadalupe Guevara
회원 가입일: 10/26/22
181 평판
안내서 1개를 작성함
CSU Los Angeles, Team 2-8, Briggs Fall 2022 CSU Los Angeles, Team 2-8, Briggs Fall 2022 회원
CSULA-BRIGGS-F22S2G8
1 회원
안내서 2개를 작성함
1가이드 댓글
Excelente informações
Kleber Silva Fernandes - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 33
지난 30일: 120
전체 시간: 2,602
