주요 콘텐츠로 건너뛰기
2021 Toyota Venza Key Fob Battery Replacement
필요한 것
  1. 2021 Toyota Venza Key Fob Battery Replacement, Key Fob Battery: 1 단계, 이미지 1/2 2021 Toyota Venza Key Fob Battery Replacement, Key Fob Battery: 1 단계, 이미지 2/2
    • Flip the fob so the backside is facing up.
  2. 2021 Toyota Venza Key Fob Battery Replacement: 2 단계, 이미지 1/3 2021 Toyota Venza Key Fob Battery Replacement: 2 단계, 이미지 2/3 2021 Toyota Venza Key Fob Battery Replacement: 2 단계, 이미지 3/3
    • Slide the lock to the right.
    • Pull the key out from the top of fob case.
  3. 2021 Toyota Venza Key Fob Battery Replacement: 3 단계, 이미지 1/2 2021 Toyota Venza Key Fob Battery Replacement: 3 단계, 이미지 2/2
    • Insert the tip of the key or a spudger into the space where the key was and begin to pry the two parts of the fob apart.
  4. 2021 Toyota Venza Key Fob Battery Replacement: 4 단계, 이미지 1/3 2021 Toyota Venza Key Fob Battery Replacement: 4 단계, 이미지 2/3 2021 Toyota Venza Key Fob Battery Replacement: 4 단계, 이미지 3/3
    • If that doesn't work twist the key slightly and open up the plastic case.
  5. 2021 Toyota Venza Key Fob Battery Replacement: 5 단계, 이미지 1/2 2021 Toyota Venza Key Fob Battery Replacement: 5 단계, 이미지 2/2
    • Gently remove the old battery.
  6. 2021 Toyota Venza Key Fob Battery Replacement: 6 단계, 이미지 1/2 2021 Toyota Venza Key Fob Battery Replacement: 6 단계, 이미지 2/2
    • Insert a new CR2450 lithium cell battery.
  7. 2021 Toyota Venza Key Fob Battery Replacement: 7 단계, 이미지 1/2 2021 Toyota Venza Key Fob Battery Replacement: 7 단계, 이미지 2/2
    • Replace the back case.
    • Press the two halves together and snap it shut.
  8. 2021 Toyota Venza Key Fob Battery Replacement: 8 단계, 이미지 1/3 2021 Toyota Venza Key Fob Battery Replacement: 8 단계, 이미지 2/3 2021 Toyota Venza Key Fob Battery Replacement: 8 단계, 이미지 3/3
    • Insert the key back into the case.
    • You're done!
결론
Press on the controller, and if a red light is shown when pressed, battery replacement is a success.
To double-check, go to your Toyota Venza and press the unlock or lock button; if the car responds, the battery works perfectly fine.
MGaliciaDiaz
회원 가입일: 03/05/24
157 평판
안내서 1개 작성함
CSU Los Angeles, Team 7-5, Grodsky Spring 2024 CSU Los Angeles, Team 7-5, Grodsky Spring 2024 회원
CSULA-GRODSKY-S24S7G5
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 13
30일 전: 110
전체 시간: 203
