소개
This page will guide you on the replacement of the battery on your 360fly 4K camera.
필요한 것
Flip the camera upside down and peel off the two plastic screw covers with the metal spudger to reveal the screws.
Remove the five 4 mm screws around the battery assembly with a T4 screwdriver.
Lift the battery assembly and gently pry the plug out of its port on the board below with a plastic opening tool.
Press the battery from the back of the battery assembly to remove it with a plastic opening tool until the glue releases the battery.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 4개
Wich one battery Can I use to replace It?
Where can i purchase a battery
I would like to purchase a 360 fly battery
