주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
360fly 4K Lens Replacement
필요한 것
    1. 360fly 4K Lens Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Flip the camera upside down and peel off the two plastic screw covers with the metal spudger to reveal the screws.
      댓글 쓰기
    2. 360fly 4K Lens Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the two 5 mm screws from the bottom of the camera with a T4 screwdriver.
      댓글 쓰기
    3. 360fly 4K Lens Replacement: 3 단계, 이미지 2개 중 1개 360fly 4K Lens Replacement: 3 단계, 이미지 2개 중 2개
      • Gently pry the plastic ring from around the charging plate with the metal spudger.
      • Remove the outside shell by pressing against the center of the charging plate and pulling the bottom shell away from the top shell.
      댓글 쓰기
    4. 360fly 4K Lens Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the five 2 mm screws using a T4 screwdriver.
      • Pull off the charging plate assembly.
      댓글 쓰기
    5. 360fly 4K Lens Replacement: 5 단계, 이미지 2개 중 1개 360fly 4K Lens Replacement: 5 단계, 이미지 2개 중 2개
      • Gently pry the plug off the port on the circuit board with a plastic opening tool.
      • Remove the four 2 mm screws using a T4 screwdriver.
      • Remove the circuit board from the device.
      댓글 쓰기
    6. 360fly 4K Lens Replacement: 6 단계, 이미지 3개 중 1개 360fly 4K Lens Replacement: 6 단계, 이미지 3개 중 2개 360fly 4K Lens Replacement: 6 단계, 이미지 3개 중 3개
      • Remove the five 4 mm screws around the battery assembly with a T4 screwdriver.
      • Lift the battery assembly and gently pry the plug out of its port on the board below with a plastic opening tool.
      • Press the battery from the back of the battery assembly to remove it with a plastic opening tool until the glue releases the battery.
      • Potential for device damage: Do not puncture or bend the battery. Use a small amount of heat to assist in softening the adhesive if necessary.
      댓글 쓰기
    1. 360fly 4K Lens Replacement, SD Card: 7 단계, 이미지 1개 중 1개
      • Gently pry the plug from the motherboard and remove the motherboard from the assembly.
      댓글 쓰기
    2. 360fly 4K Lens Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the three 3 mm screws from the circuit assembly with a T4 screwdriver.
      댓글 쓰기
    3. 360fly 4K Lens Replacement: 9 단계, 이미지 1개 중 1개
      • Gently pry out the plug from the circuit assembly.
      댓글 쓰기
    4. 360fly 4K Lens Replacement: 10 단계, 이미지 1개 중 1개
      • Press and release the SD card to remove it from the circuit assembly.
      댓글 쓰기
    1. 360fly 4K Lens Replacement, Lens: 11 단계, 이미지 1개 중 1개
      • Unscrew the five 3mm screws with a T4 screwdriver.
      댓글 쓰기
    2. 360fly 4K Lens Replacement: 12 단계, 이미지 1개 중 1개
      • Gently push against the lens module to remove it from the 360fly 4K assembly.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Jacob Herron
회원 가입일: 11/08/17
463 평판
안내서 3개를 작성함
IUPUI, Team S5-G3, Baechle Fall 2017 IUPUI, Team S5-G3, Baechle Fall 2017 회원
IUPUI-BAECHLE-F17S5G3
3 회원들
안내서 24개를 작성함
4가이드 댓글
Hi. Where to get a replacement lens as I am in need for this repair, but 360fly offer a full service for $150 and do not sell spare lenses. Thx
anguel nakov - 답글 공유
There is no info where to buy the replacement lens.
gelo3000 - 답글 공유
Anyone know about usb pinout? I lost my charger adapter
Nuri Can PEHLİVAN - 답글 공유
Hi.
I inadvertently found your question.
I have this same problem.
I've lost the charger, too, and now I'm looking for a chance to charge without a base, or a chance to buy a base.
Imants
Imants R - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 37
전체 시간: 2,363
