주요 콘텐츠로 건너뛰기
360fly 4K SD Card Replacement
필요한 것
  1. 360fly 4K SD Card Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the camera upside down and peel off the two plastic screw covers with the metal spudger to reveal the screws.
  2. 360fly 4K SD Card Replacement: 2 단계, 이미지 1/1
    • Remove the two 5 mm screws from the bottom of the camera with a T4 screwdriver.
  3. 360fly 4K SD Card Replacement: 3 단계, 이미지 1/2 360fly 4K SD Card Replacement: 3 단계, 이미지 2/2
    • Gently pry the plastic ring from around the charging plate with the metal spudger.
    • Remove the outside shell by pressing against the center of the charging plate and pulling the bottom shell away from the top shell.
  4. 360fly 4K SD Card Replacement: 4 단계, 이미지 1/1
    • Remove the five 2 mm screws using a T4 screwdriver.
    • Pull off the charging plate assembly.
  5. 360fly 4K SD Card Replacement: 5 단계, 이미지 1/2 360fly 4K SD Card Replacement: 5 단계, 이미지 2/2
    • Gently pry the plug off the port on the circuit board with a plastic opening tool.
    • Remove the four 2 mm screws using a T4 screwdriver.
    • Remove the circuit board from the device.
  6. 360fly 4K SD Card Replacement: 6 단계, 이미지 1/3 360fly 4K SD Card Replacement: 6 단계, 이미지 2/3 360fly 4K SD Card Replacement: 6 단계, 이미지 3/3
    • Remove the five 4 mm screws around the battery assembly with a T4 screwdriver.
    • Lift the battery assembly and gently pry the plug out of its port on the board below with a plastic opening tool.
    • Press the battery from the back of the battery assembly to remove it with a plastic opening tool until the glue releases the battery.
    • Potential for device damage: Do not puncture or bend the battery. Use a small amount of heat to assist in softening the adhesive if necessary.
  7. 360fly 4K SD Card Replacement, SD Card: 7 단계, 이미지 1/1
    • Gently pry the plug from the motherboard and remove the motherboard from the assembly.
  8. 360fly 4K SD Card Replacement: 8 단계, 이미지 1/1
    • Remove the three 3 mm screws from the circuit assembly with a T4 screwdriver.
  9. 360fly 4K SD Card Replacement: 9 단계, 이미지 1/1
    • Gently pry out the plug from the circuit assembly.
  10. 360fly 4K SD Card Replacement: 10 단계, 이미지 1/1
    • Press and release the SD card to remove it from the circuit assembly.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Jacob Herron
회원 가입일: 11/08/17
463 평판
안내서 3개 작성하였습니다
IUPUI, Team S5-G3, Baechle Fall 2017 IUPUI, Team S5-G3, Baechle Fall 2017 회원
IUPUI-BAECHLE-F17S5G3
3 회원들
안내서 3개 작성하였습니다
댓글 한 개
Really useful guide, thanks
John Erikson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 12
전체 시간: 1,074
