주요 콘텐츠로 건너뛰기
3DR Iris Plus Quadcopter Bottom Shell Replacement
필요한 것
  1. 3DR Iris Plus Quadcopter Bottom Shell Replacement, Bottom Shell: 1 단계, 이미지 1/2 3DR Iris Plus Quadcopter Bottom Shell Replacement, Bottom Shell: 1 단계, 이미지 2/2
    • Remove the eight 11mm screws attaching the underbody of the drone using the 2mm Hex screwdriver/key.
  2. 3DR Iris Plus Quadcopter Bottom Shell Replacement: 2 단계, 이미지 1/3 3DR Iris Plus Quadcopter Bottom Shell Replacement: 2 단계, 이미지 2/3 3DR Iris Plus Quadcopter Bottom Shell Replacement: 2 단계, 이미지 3/3
    • Remove the two larger, 12mm screws attached to the Go Pro mount using the 3mm Hex screwdriver/key.
    • Lift to remove the mount.
  3. 3DR Iris Plus Quadcopter Bottom Shell Replacement: 3 단계, 이미지 1/3 3DR Iris Plus Quadcopter Bottom Shell Replacement: 3 단계, 이미지 2/3 3DR Iris Plus Quadcopter Bottom Shell Replacement: 3 단계, 이미지 3/3
    • Feed both wires through the grill of the bottom shell.
    • Lift to remove the shell.
    • There are two cables tethering the shell to the body of the drone. It is difficult and unnecessary to remove them. Simply lay the shell to the side.
결론
Evan Witulski
회원 가입일: 02/10/20
349 평판
안내서 3개 작성하였습니다
Cal Poly, Team S7-G5, Regan Winter 2020 Cal Poly, Team S7-G5, Regan Winter 2020 회원
CPSU-REGAN-W20S7G5
5 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 140
