주요 콘텐츠로 건너뛰기
3DR Iris Plus Quadcopter Gimbal Removal Procedure
필요한 것
  1. 3DR Iris Plus Quadcopter Gimbal Removal Procedure, Gimbal: 1 단계, 이미지 1/3 3DR Iris Plus Quadcopter Gimbal Removal Procedure, Gimbal: 1 단계, 이미지 2/3 3DR Iris Plus Quadcopter Gimbal Removal Procedure, Gimbal: 1 단계, 이미지 3/3
    • If your drone is equipped with it, remove the video transmitter.
    • Disconnect all cables from the gimbal.
    • If your drone has neither the gimbal or video transmitter, you can skip this step.
  2. 3DR Iris Plus Quadcopter Gimbal Removal Procedure: 2 단계, 이미지 1/2 3DR Iris Plus Quadcopter Gimbal Removal Procedure: 2 단계, 이미지 2/2
    • Unscrew the 16 mm screw attaching the gimbal mount to the body of the drone using the 3 mm Hex screwdriver/key.
  3. 3DR Iris Plus Quadcopter Gimbal Removal Procedure: 3 단계, 이미지 1/2 3DR Iris Plus Quadcopter Gimbal Removal Procedure: 3 단계, 이미지 2/2
    • Rotate the drone 180 degrees.
    • Unscrew the other 16mm gimbal mount screw using the 3 mm Hex screwdriver/key.
  4. 3DR Iris Plus Quadcopter Gimbal Removal Procedure: 4 단계, 이미지 1/1
    • Remove the gimbal mount from the body of the drone.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Evan Witulski
회원 가입일: 02/10/20
349 평판
안내서 3개 작성하였습니다
Cal Poly, Team S7-G5, Regan Winter 2020 Cal Poly, Team S7-G5, Regan Winter 2020 회원
CPSU-REGAN-W20S7G5
5 회원들
안내서 9개 작성하였습니다
댓글 한 개
Where are the two wires connect to the gimbal one is a ground and the white wire connects to the power, but where?
James Reed - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 6
전체 시간: 199
