주요 콘텐츠로 건너뛰기
3DR Iris Plus Quadcopter Motor Replacement
필요한 것
  1. 3DR Iris Plus Quadcopter Motor Replacement, Battery: 1 단계, 이미지 1/1
    • Power off the drone by holding down the power button.
    • Remove the battery by disconnecting it from the main battery connector.
    • Press the power button again to ensure all electricity is discharged.
    • This step is imperative as it is dangerous to handle drone components with a running current!
  2. 3DR Iris Plus Quadcopter Motor Replacement, Propeller: 2 단계, 이미지 1/2 3DR Iris Plus Quadcopter Motor Replacement, Propeller: 2 단계, 이미지 2/2
    • Take note of the propeller cap color (either black or silver).
    • Hold down the motor assembly and twist the propeller clockwise to unlock it (you should feel some resistance until it starts to unscrew freely).
    • Hold down the motor assembly and twist the propeller counterclockwise to unlock it (you should feel some resistance until it starts to unscrew freely).
    • This is the motor assembly.
  3. 3DR Iris Plus Quadcopter Motor Replacement: 3 단계, 이미지 1/2 3DR Iris Plus Quadcopter Motor Replacement: 3 단계, 이미지 2/2
    • Ensure that the propeller cap color (black or silver) matches the propeller screw cap color.
    • There are two different types of propellers so make sure you're using the correct one.
  4. 3DR Iris Plus Quadcopter Motor Replacement, Gimbal: 4 단계, 이미지 1/3 3DR Iris Plus Quadcopter Motor Replacement, Gimbal: 4 단계, 이미지 2/3 3DR Iris Plus Quadcopter Motor Replacement, Gimbal: 4 단계, 이미지 3/3
    • If your drone is equipped with it, remove the video transmitter.
    • Disconnect all cables from the gimbal.
    • If your drone has neither the gimbal or video transmitter, you can skip this step.
  5. 3DR Iris Plus Quadcopter Motor Replacement: 5 단계, 이미지 1/2 3DR Iris Plus Quadcopter Motor Replacement: 5 단계, 이미지 2/2
    • Unscrew the 16 mm screw attaching the gimbal mount to the body of the drone using the 3 mm Hex screwdriver/key.
  6. 3DR Iris Plus Quadcopter Motor Replacement: 6 단계, 이미지 1/2 3DR Iris Plus Quadcopter Motor Replacement: 6 단계, 이미지 2/2
    • Rotate the drone 180 degrees.
    • Unscrew the other 16mm gimbal mount screw using the 3 mm Hex screwdriver/key.
  7. 3DR Iris Plus Quadcopter Motor Replacement: 7 단계, 이미지 1/1
    • Remove the gimbal mount from the body of the drone.
  8. 3DR Iris Plus Quadcopter Motor Replacement, Bottom Shell: 8 단계, 이미지 1/2 3DR Iris Plus Quadcopter Motor Replacement, Bottom Shell: 8 단계, 이미지 2/2
    • Remove the eight 11mm screws attaching the underbody of the drone using the 2mm Hex screwdriver/key.
  9. 3DR Iris Plus Quadcopter Motor Replacement: 9 단계, 이미지 1/3 3DR Iris Plus Quadcopter Motor Replacement: 9 단계, 이미지 2/3 3DR Iris Plus Quadcopter Motor Replacement: 9 단계, 이미지 3/3
    • Remove the two larger, 12mm screws attached to the Go Pro mount using the 3mm Hex screwdriver/key.
    • Lift to remove the mount.
  10. 3DR Iris Plus Quadcopter Motor Replacement: 10 단계, 이미지 1/3 3DR Iris Plus Quadcopter Motor Replacement: 10 단계, 이미지 2/3 3DR Iris Plus Quadcopter Motor Replacement: 10 단계, 이미지 3/3
    • Feed both wires through the grill of the bottom shell.
    • Lift to remove the shell.
    • There are two cables tethering the shell to the body of the drone. It is difficult and unnecessary to remove them. Simply lay the shell to the side.
  11. 3DR Iris Plus Quadcopter Motor Replacement, Motor: 11 단계, 이미지 1/2 3DR Iris Plus Quadcopter Motor Replacement, Motor: 11 단계, 이미지 2/2
    • Ensure that the drone is in the same orientation as the picture (power connector and capacitors on the bottom).
    • Top-left motor power cables
    • Top-right motor power cables
    • Bottom-left motor power cables
    • Bottom-right motor power cables
    • Desolder the motor power cables closest to the motor that you are replacing (the cables in each corner route to the closest leg).
    • Exercise caution and follow proper desoldering procedures to ensure safety.
  12. 3DR Iris Plus Quadcopter Motor Replacement: 12 단계, 이미지 1/2 3DR Iris Plus Quadcopter Motor Replacement: 12 단계, 이미지 2/2
    • On the leg that the motor is attached to, remove the 8mm screw that holds the long leg foot in place using the 1.5 mm Hex screwdriver/key.
  13. 3DR Iris Plus Quadcopter Motor Replacement: 13 단계, 이미지 1/3 3DR Iris Plus Quadcopter Motor Replacement: 13 단계, 이미지 2/3 3DR Iris Plus Quadcopter Motor Replacement: 13 단계, 이미지 3/3
    • Slide the leg foot out of the leg assembly.
  14. 3DR Iris Plus Quadcopter Motor Replacement: 14 단계, 이미지 1/3 3DR Iris Plus Quadcopter Motor Replacement: 14 단계, 이미지 2/3 3DR Iris Plus Quadcopter Motor Replacement: 14 단계, 이미지 3/3
    • Remove each of the plastic clips holding the motor cables in by snapping them out.
    • Remove the two 9mm screws using a 2 mm Hex screwdriver/key. Once removed, the motor will hang freely from the leg chassis.
    • Remove the LED assembly by snapping it off the clips that are attached to the drone leg.
  15. 3DR Iris Plus Quadcopter Motor Replacement: 15 단계, 이미지 1/1
    • To remove the motor assembly, pull the motor assembly through and out of the leg chassis.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Duncan Applegarth
회원 가입일: 02/10/20
316 평판
안내서 3개 작성하였습니다
Cal Poly, Team S7-G5, Regan Winter 2020 Cal Poly, Team S7-G5, Regan Winter 2020 회원
CPSU-REGAN-W20S7G5
5 회원들
안내서 9개 작성하였습니다
댓글 한 개
Thanks for the info Duncan , I am finding it difficult to simply snap off the led clip away from the arm is there a secret? Lol!
Kevin Lewis - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 598
