주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
3DR Solo Leg Replacement
필요한 것
    1. 3DR Solo Leg Replacement, Propeller: 1 단계, 이미지 1개 중 1개
      • Grip the arm, which is located underneath the propeller, with one hand, and with your dominant hand grip the center of the propeller.
      댓글 쓰기
    2. 3DR Solo Leg Replacement: 2 단계, 이미지 1개 중 1개
      • Twist the propeller from the locked to unlocked position as indicated by the images of the lock.
      • You will need to twist in this direction for 2-3 full rotations before the propeller will detach.
      댓글 쓰기
    3. 3DR Solo Leg Replacement: 3 단계, 이미지 1개 중 1개
      • Lift the propeller off the motor.
      • To remove the silver-top propellers, repeat these steps, turning the propellers in the opposite direction of the black-top propellers.
      댓글 쓰기
    1. 3DR Solo Leg Replacement, Leg: 4 단계, 이미지 1개 중 1개
      • Place the controller on a flat surface with the battery side down.
      댓글 쓰기
    2. 3DR Solo Leg Replacement: 5 단계, 이미지 3개 중 1개 3DR Solo Leg Replacement: 5 단계, 이미지 3개 중 2개 3DR Solo Leg Replacement: 5 단계, 이미지 3개 중 3개
      • Locate the leg and remove the two 10mm screws that hold the leg in place.
      댓글 쓰기
    3. 3DR Solo Leg Replacement: 6 단계, 이미지 1개 중 1개
      • Gently pull the leg up to remove it from its position.
      • Leg should be connected by a black wire.
      댓글 쓰기
    4. 3DR Solo Leg Replacement: 7 단계, 이미지 3개 중 1개 3DR Solo Leg Replacement: 7 단계, 이미지 3개 중 2개 3DR Solo Leg Replacement: 7 단계, 이미지 3개 중 3개
      • Locate the rubber grip at the end of the leg and, with your thumb, peel it back and pull it off.
      댓글 쓰기
    5. 3DR Solo Leg Replacement: 8 단계, 이미지 2개 중 1개 3DR Solo Leg Replacement: 8 단계, 이미지 2개 중 2개
      • Leg type 1 will contain a 1mm screw at the base of the leg.
      • Unscrew the 1mm screw located at the end of the leg.
      댓글 쓰기
    6. 3DR Solo Leg Replacement: 9 단계, 이미지 1개 중 1개
      • Gently pull the black cord up to release it from the leg.
      댓글 쓰기
    7. 3DR Solo Leg Replacement: 10 단계, 이미지 3개 중 1개 3DR Solo Leg Replacement: 10 단계, 이미지 3개 중 2개 3DR Solo Leg Replacement: 10 단계, 이미지 3개 중 3개
      • Leg type 2 will contain the antenna wire.
      • Gently pull up on and remove the plastic covering labeled "solo antenna".
      • Locate the antenna wire and carefully pull up and remove it.
      • The antenna wire is flimsy so use caution upon removal.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Leia Harlow
회원 가입일: 09/11/17
104 평판
안내서 1개를 작성함
CSU Fullerton, Team S2-G3, Bruce Fall 2017 CSU Fullerton, Team S2-G3, Bruce Fall 2017 회원
CSUF-BRUCE-F17S2G3
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 27
전체 시간: 650
