주요 콘텐츠로 건너뛰기
3rd party DualShock 2 Wireless Controller Analog Stick Replacement
필요한 것
  1. 3rd party DualShock 2 Wireless Controller Analog Stick Replacement, Analog Stick: 1 단계, 이미지 2개 중 1개 3rd party DualShock 2 Wireless Controller Analog Stick Replacement, Analog Stick: 1 단계, 이미지 2개 중 2개
    • Remove the six 7.8 mm anchoring screws from the back casing of the controller using a Phillips #0 screwdriver.
  2. 3rd party DualShock 2 Wireless Controller Analog Stick Replacement: 2 단계, 이미지 2개 중 1개 3rd party DualShock 2 Wireless Controller Analog Stick Replacement: 2 단계, 이미지 2개 중 2개
    • Pull apart the outer casing by hand, or by using a plastic opening tool, from the bottom of the controller.
    • Be mindful not to sever the connection between the battery pack attached to the back casing and the internal board
  3. 3rd party DualShock 2 Wireless Controller Analog Stick Replacement: 3 단계, 이미지 2개 중 1개 3rd party DualShock 2 Wireless Controller Analog Stick Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the two 6.1 mm screws holding the internal analog stick board and the front of the controller together.
  4. 3rd party DualShock 2 Wireless Controller Analog Stick Replacement: 4 단계, 이미지 2개 중 1개 3rd party DualShock 2 Wireless Controller Analog Stick Replacement: 4 단계, 이미지 2개 중 2개
    • Lift the analog stick board away from the front of the controller.
    • Remove the detached or loose analog stick for realignment.
  5. 3rd party DualShock 2 Wireless Controller Analog Stick Replacement: 5 단계, 이미지 1개 중 1개
    • Realign the analog stick by pushing the removed stick back into its chassis with focus on pushing it in at the new, desired resting angle. You should feel or hear a small click if done correctly.
    • The stick may not immediately click into place under the pressure. Instead of pushing harder, try rotating the stick 90 degrees and pushing down again.
결론
다른 22명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Roger Campbell
회원 가입일: 07/12/17
377 평판
안내서 1개를 작성함
Texas Tech, Team S1-G1, Rauch Summer 2017 Texas Tech, Team S1-G1, Rauch Summer 2017 회원
TTU-RAUCH-SU17S1G1
2 회원들
안내서 4개를 작성함
1가이드 댓글
The controller featured here is not an official Dualshock 2 controller.
Synapse - 답글
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 82
지난 30일: 313
전체 시간: 17,650
