주요 콘텐츠로 건너뛰기
4-Stroke Small Gas Engine Air Filter Replacement
필요한 것
  1. 4-Stroke Small Gas Engine Air Filter Replacement, Air Filter: 1 단계, 이미지 1/3 4-Stroke Small Gas Engine Air Filter Replacement, Air Filter: 1 단계, 이미지 2/3 4-Stroke Small Gas Engine Air Filter Replacement, Air Filter: 1 단계, 이미지 3/3
    • Before starting, ensure that the engine is not running and is not hot.
    • Pull the tab until the filter cover opens. Remove the filter cover.
    • Note that the bottom of the cover is hinged.
  2. 4-Stroke Small Gas Engine Air Filter Replacement: 2 단계, 이미지 1/1
    • Remove the air filter.
    • The air filter will be either an oily sponge, or an accordion-folded fabric.
    • Note that the air filter is saturated with oil. Wear gloves and use paper towels to avoid creating a mess.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Ethan Narad
회원 가입일: 04/19/18
529 평판
안내서 3개 작성하였습니다
Cal Poly, Team S25-G15, Maness Spring 2018 Cal Poly, Team S25-G15, Maness Spring 2018 회원
CPSU-MANESS-S18S25G15
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 5
30일 전: 10
전체 시간: 631
