주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
42" LG TV LED Strip Replacement Tutorial
동영상 개요
  1. 42" LG TV LED Strip Replacement Tutorial, LED Strip Replacement Tutorial: 1 단계, 이미지 1개 중 1개
    • Remove the screws from the rear of the television, as well as the back cover.
  2. 42" LG TV LED Strip Replacement Tutorial: 2 단계, 이미지 1개 중 1개
    • Remove the screws that connect the IR sensor to the mainboard to remove and detach it.
  3. 42" LG TV LED Strip Replacement Tutorial: 3 단계, 이미지 1개 중 1개
    • Disconnect the ribbon wires from the buffer boards using the provided connectors.
  4. 42" LG TV LED Strip Replacement Tutorial: 4 단계, 이미지 1개 중 1개
    • Remove the speakers from the mainboard by disconnecting them from it.
  5. 42" LG TV LED Strip Replacement Tutorial: 5 단계, 이미지 1개 중 1개
    • Remove the screws on the assembly that are around the television.
  6. 42" LG TV LED Strip Replacement Tutorial: 6 단계, 이미지 1개 중 1개
    • Remove the screws that hold the buffer board in place.
  7. 42" LG TV LED Strip Replacement Tutorial: 7 단계, 이미지 1개 중 1개
    • For certain covers, you may need to pry the clips away from the bezel using a five-in-one tool or something similar to free the clips.
  8. 42" LG TV LED Strip Replacement Tutorial: 8 단계, 이미지 1개 중 1개
    • Remove the buffer board covers from the board.
  9. 42" LG TV LED Strip Replacement Tutorial: 9 단계, 이미지 1개 중 1개
    • To get the buffer boards free, release the tabs on the boards.
  10. 42" LG TV LED Strip Replacement Tutorial: 10 단계, 이미지 1개 중 1개
    • Remove the bezel by flipping the television over.
  11. 42" LG TV LED Strip Replacement Tutorial: 11 단계, 이미지 1개 중 1개
    • Flip up the buffer boards and tape them to the panel using suction cups.
  12. 42" LG TV LED Strip Replacement Tutorial: 12 단계, 이미지 1개 중 1개
    • Remove the panel off the television by lifting it evenly so that it does not break.
  13. 42" LG TV LED Strip Replacement Tutorial: 13 단계, 이미지 1개 중 1개
    • Remove the panel frame.
  14. 42" LG TV LED Strip Replacement Tutorial: 14 단계, 이미지 1개 중 1개
    • Tape the diffusion layers together at the corner to keep them aligned, then remove the layers of diffusion one by one, starting at the corner.
  15. 42" LG TV LED Strip Replacement Tutorial: 15 단계, 이미지 1개 중 1개
    • The reflector is held in place by two sets of tabs located on each side of it.
  16. 42" LG TV LED Strip Replacement Tutorial: 16 단계, 이미지 1개 중 1개
    • Pinch the smaller tabs through the chassis on the board side, using needle-nose pliers to get them tight.
  17. 42" LG TV LED Strip Replacement Tutorial: 17 단계, 이미지 1개 중 1개
    • Some of the smaller tabs may be placed under the boards; to reach at least one of the smaller tabs, you will need to remove the t-con board.
  18. 42" LG TV LED Strip Replacement Tutorial: 18 단계, 이미지 1개 중 1개
    • To release the bigger tabs, you will need to raise one side while sliding it.
  19. 42" LG TV LED Strip Replacement Tutorial: 19 단계, 이미지 1개 중 1개
    • Remove the reflector sheet.
  20. 42" LG TV LED Strip Replacement Tutorial: 20 단계, 이미지 1개 중 1개
    • Use a five-in-one tool or something similar to disconnect the LED strips from the power cables and pry underneath the LED strips to lift them out of their mounting brackets on the chassis.
  21. 42" LG TV LED Strip Replacement Tutorial: 21 단계, 이미지 1개 중 1개
    • Connect the new LED strips and make sure they are properly aligned on the chassis.
  22. 42" LG TV LED Strip Replacement Tutorial: 22 단계, 이미지 1개 중 1개
    • Reconnect the LED strips to the power cable as they have been disconnected.
  23. 42" LG TV LED Strip Replacement Tutorial: 23 단계, 이미지 1개 중 1개
    • Reconnect the reflector sheet and clips to the reflector frame.
  24. 42" LG TV LED Strip Replacement Tutorial: 24 단계, 이미지 1개 중 1개
    • Remove the tape from the layers of diffusion and reinstall them.
  25. 42" LG TV LED Strip Replacement Tutorial: 25 단계, 이미지 1개 중 1개
    • Reinstall the panel frame.
  26. 42" LG TV LED Strip Replacement Tutorial: 26 단계, 이미지 1개 중 1개
    • Adjust the panel's position and then remove the suction cups.
  27. 42" LG TV LED Strip Replacement Tutorial: 27 단계, 이미지 1개 중 1개
    • Release the buffer boards from the tape.
  28. 42" LG TV LED Strip Replacement Tutorial: 28 단계, 이미지 1개 중 1개
    • Reinstall the bezel and tighten it down using the screws that run around the perimeter of the TV.
  29. 42" LG TV LED Strip Replacement Tutorial: 29 단계, 이미지 1개 중 1개
    • Reinstall the buffer board covers on the board.
  30. 42" LG TV LED Strip Replacement Tutorial: 30 단계, 이미지 1개 중 1개
    • Reconnect the t-con board and ribbon wires as they are disconnected.
  31. 42" LG TV LED Strip Replacement Tutorial: 31 단계, 이미지 1개 중 1개
    • Reinstall the speakers and connect the wire to the mainboard.
  32. 42" LG TV LED Strip Replacement Tutorial: 32 단계, 이미지 1개 중 1개
    • Reinstall the infrared sensor and tighten it to the chassis once more.
  33. 42" LG TV LED Strip Replacement Tutorial: 33 단계, 이미지 1개 중 1개
    • Reinstall the back cover and put the screws back in place.
결론
Removing and Reinstalling 4G LG TV LED Strips may sound tricky or complicated; however, after reading this tutorial for replacing the LED strips of LG 42inch LED TV, you can do it by yourself now! I hope you enjoy it. See you in the next tutorial.
다른 21명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Rachel Burnham
회원 가입일: 07/16/21
1,101 평판
안내서 1개를 작성함
5가이드 댓글
Tv Lg 42lv3500 no se ve imagen , lo único que se ve son líneas de color verticales y luego van desapareciendo hasta quedar en negro , me podrían ayudar por favor
carlos fagundez - 답글 공유
No one ever shows how to get the wire adapters off the ends of the LED strips! Also, the spacers are very brittle, if you put a 5 in one under it, it will break. Take them off from behind and just push it in a little where the catch is and slide it gently on the face side.
Kevin York - 답글 공유
My Tv is blank (not showing picture but has a black light display instead of pictures) but still plays sound loud and clear. What could be the problem please? “LG 43" smart. Model 43uk6400plf. Firmware 5.50.15”
AfolabI Olakanmi - 답글 공유
Mine has the similar situation, no picture shown most the time and whenever picture is on, left half of the screen is flickering with white stripes (on and off) , I thought it might be the display controller's problem but not sure, will someone could guide a direction on how to fix it?
Sherman
Sherman Hsu - 답글 공유
Hola, mi televisor LG lo apretaron mucho y malogrado la pantalla de tal manera q ahora solo se ven unas línea de colores, no se ve imagen
Janet - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 61
지난 7일: 351
지난 30일: 1,587
전체 시간: 75,597
