주요 콘텐츠로 건너뛰기
5 Tips & Tricks for HTC Desire 510
동영상 개요
  1. 5 Tips & Tricks for HTC Desire 510, TEST MENU: 1 단계, 이미지 1/3 5 Tips & Tricks for HTC Desire 510, TEST MENU: 1 단계, 이미지 2/3 5 Tips & Tricks for HTC Desire 510, TEST MENU: 1 단계, 이미지 3/3
    • Open the dealer app and enter this code:
    • *#3424#*#*
  2. 5 Tips & Tricks for HTC Desire 510, SAFE MODE: 2 단계, 이미지 1/3 5 Tips & Tricks for HTC Desire 510, SAFE MODE: 2 단계, 이미지 2/3 5 Tips & Tricks for HTC Desire 510, SAFE MODE: 2 단계, 이미지 3/3
    • Open Power off menu.
    • Tab and hold Power off option until you see Reboot to safe mode menu and select Restart.
    • The phone will restarts to safe mode.
    • To turn off Safe mode, remove the battery.
  3. 5 Tips & Tricks for HTC Desire 510, DEVELOPER OPTIONS: 3 단계, 이미지 1/3 5 Tips & Tricks for HTC Desire 510, DEVELOPER OPTIONS: 3 단계, 이미지 2/3 5 Tips & Tricks for HTC Desire 510, DEVELOPER OPTIONS: 3 단계, 이미지 3/3
    • > Settings
    • > About
    • > Software Information
    • > More
    • Tap Buld number 7 times.
    • Your Developer options menu is unlocked. In this menu you will find settings used for debugging and application development.
    • If you want to root the phone, you have to enable USB debugging from this menu.
    • Do NOT change the settings unless you know what you are doing.
  4. 5 Tips & Tricks for HTC Desire 510, INFO MENU: 4 단계, 이미지 1/3 5 Tips & Tricks for HTC Desire 510, INFO MENU: 4 단계, 이미지 2/3 5 Tips & Tricks for HTC Desire 510, INFO MENU: 4 단계, 이미지 3/3
    • From the dealer app enter this code:
    • *#*#4636#*#*
    • Here you will find some helpful information for your device.
  5. 5 Tips & Tricks for HTC Desire 510, SNAPSHOT: 5 단계, 이미지 1/2 5 Tips & Tricks for HTC Desire 510, SNAPSHOT: 5 단계, 이미지 2/2
    • To make a screenshot press simultaneously:
    • Volume Down + Power or
    • Home + Powe
    • That's all.
결론
다른 8명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,278 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,528개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 1,559
