주요 콘텐츠로 건너뛰기
6. Installing Klipper Screen
  1. 6. Installing Klipper Screen, 6. Installing Klipper Screen: 1 단계, 이미지 1개 중 1개
    • You need to set the OS to boot to console
    • sudo raspi-config
    • 1 System Options > S5 Boot / Auto Login > B1 Console. Then reboot
    • Download and install KlipperScreen
    • git clone https://github.com/jordanruthe/KlipperSc...
    • cd ~/KlipperScreen
    • ./scripts/KlipperScreen-install.sh
    • When the install is finished reboot the RPI. This will take some time to install so feel free to get yourself a cold beverage and relax for a little bit.
  2. 6. Installing Klipper Screen: 2 단계, 이미지 1개 중 1개
    • If you loaded my config files it should already be included but check moonraker.conf contains:
    • [authorization] under trusted clients contains 127.0.0.1
    • [update manager KlipperScreen]
  3. 6. Installing Klipper Screen: 3 단계, 이미지 2개 중 1개 6. Installing Klipper Screen: 3 단계, 이미지 2개 중 2개
    • If you used the latest version of Mainsail(v7.0) skip this next command.
    • git clone https://github.com/mainsail-crew/moonrak...
    • Regardless if you used the latest version or not run
    • bash ~/moonraker-timelapse/install.sh
    • Make sure printer.cfg calls the timelapse config
    • [include timelapse.cfg]
    • Make sure the [timelapse] section is uncommented in moonraker.conf
결승점
작성자
1다른 기여자 명과 함께
David Husolo
회원 가입일: 06/16/21
9,232 평판
안내서 33개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 13
전체 시간: 1,959
