주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
8BitDo SN30 Pro+ Controller Joystick Caps Replacement
필요한 것
  1. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Battery: 1 단계, 이미지 3개 중 1개 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Battery: 1 단계, 이미지 3개 중 2개 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Battery: 1 단계, 이미지 3개 중 3개
    • Place the controller face down.
    • Remove the battery cover.
    • Remove rechargeable battery or AA batteries.
  2. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Trigger Buttons: 2 단계, 이미지 2개 중 1개 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Trigger Buttons: 2 단계, 이미지 2개 중 2개
    • Remove L2 and R2 trigger buttons by pushing them away from the grips.
  3. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Screws: 3 단계, 이미지 2개 중 1개 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Screws: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use Tweezers to uncover two screws under the label in the battery compartment.
    • Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
  4. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Unclip Covers: 4 단계, 이미지 3개 중 1개 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Unclip Covers: 4 단계, 이미지 3개 중 2개 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Unclip Covers: 4 단계, 이미지 3개 중 3개
    • At the end of each grip, pry apart the covers.
    • Use fingernail or opening pick to undo the two top clips.
    • One clip next to L button.
    • One clip next to R button
    • Undo the final clip between the joysticks.
  5. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Separate Covers: 5 단계, 이미지 1개 중 1개
    • Carefully move the rear cover away and from the front cover. Place it to the left.
    • Do not completely separate. The two halves are still attached via a white ribbon cable.
  6. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Caps: 6 단계, 이미지 3개 중 1개 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Caps: 6 단계, 이미지 3개 중 2개 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Caps: 6 단계, 이미지 3개 중 3개
    • Grab the top and pull straight up on the joystick cap. Pulling out the caps one-by-one.
  7. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Installing New Caps: 7 단계, 이미지 3개 중 1개 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Installing New Caps: 7 단계, 이미지 3개 중 2개 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Installing New Caps: 7 단계, 이미지 3개 중 3개
    • One at a time, Orient the new cap to match the analog stick.
    • Push the cap straight down onto the analog stick.
    • You should hear the click of the stick button
결론
다른 11명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Brian W
회원 가입일: 12/21/11
1,773 평판
안내서 8개를 작성함
5가이드 댓글
Was wondering, does other brand joystick cap other than 8bitdo (eg:ps4, ps5, xbox one) fits ?
Lee Han Chang - 답글 공유
looks like PS5 hole size and cone shape. Confirmation needed.
Gustavo Klein Martins - 공유
I did the repair with a third party analog cap meant for the PS5 (being extra cheap) on the Pro 2. Despite the bottom hole being bigger on the original, the replacement joystick fit right in.
TorxT6 - 공유
Did you manage to find a replacement? Looking for an alternative as well since 8bitdo doesn't ship here.
Joseph Johansson - 답글 공유
Hello Joseph, I've purchased my replacements from Core Electronics with no issues, how ever they are based in Australia so unsure if they will ship to where you need them.
Darryn Stanmore - 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 34
지난 30일: 162
전체 시간: 5,951
