주요 콘텐츠로 건너뛰기
8BitDo SN30 Pro+ Controller Rumble Motors Replacement
필요한 것
  1. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Battery: 1 단계, 이미지 3개 중 1개 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Battery: 1 단계, 이미지 3개 중 2개 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Battery: 1 단계, 이미지 3개 중 3개
    • Place the controller face down.
    • Remove the battery cover.
    • Remove rechargeable battery or AA batteries.
  2. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Trigger Buttons: 2 단계, 이미지 2개 중 1개 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Trigger Buttons: 2 단계, 이미지 2개 중 2개
    • Remove L2 and R2 trigger buttons by pushing them away from the grips.
  3. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Screws: 3 단계, 이미지 2개 중 1개 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Screws: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use Tweezers to uncover two screws under the label in the battery compartment.
    • Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
  4. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Unclip Covers: 4 단계, 이미지 3개 중 1개 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Unclip Covers: 4 단계, 이미지 3개 중 2개 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Unclip Covers: 4 단계, 이미지 3개 중 3개
    • At the end of each grip, pry apart the covers.
    • Use fingernail or opening pick to undo the two top clips.
    • One clip next to L button.
    • One clip next to R button
    • Undo the final clip between the joysticks.
  5. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Separate Covers: 5 단계, 이미지 1개 중 1개
    • Carefully move the rear cover away and from the front cover. Place it to the left.
    • Do not completely separate. The two halves are still attached via a white ribbon cable.
  6. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Ribbon Cable: 6 단계, 이미지 3개 중 1개 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Ribbon Cable: 6 단계, 이미지 3개 중 2개 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Ribbon Cable: 6 단계, 이미지 3개 중 3개
    • Unlock the ribbon cable by push open the black plastic tab.
    • The tab will slide about 1.5mm
    • Pull the ribbon cable out of the connector in the direction of the cable.
  7. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Caps: 7 단계, 이미지 2개 중 1개 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Caps: 7 단계, 이미지 2개 중 2개
    • Grab the top and pull straight up on the joystick cap. Pulling out the caps one-by-one.
  8. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Screws: 8 단계, 이미지 3개 중 1개 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Screws: 8 단계, 이미지 3개 중 2개 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Screws: 8 단계, 이미지 3개 중 3개
    • Use a Phillips screwdriver to remove the nine 5.2 mm screws securing the rear circuit board.
    • Four around the Right stick
    • Four around the Left stick
    • One next to the Battery connector
  9. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Separate Rear Board: 9 단계, 이미지 3개 중 1개 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Separate Rear Board: 9 단계, 이미지 3개 중 2개 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Separate Rear Board: 9 단계, 이미지 3개 중 3개
    • Pull the two rumble motors out of their housings.
    • Grab the analog sticks to pull out the circuit board
  10. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Desolder Rumble Motors: 10 단계, 이미지 3개 중 1개 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Desolder Rumble Motors: 10 단계, 이미지 3개 중 2개 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Desolder Rumble Motors: 10 단계, 이미지 3개 중 3개
    • Flip over the rear board
    • Using a soldering iron to desolder the rumble motor wires.
    • During reassembly, remember to solder the wires back into the same position.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Brian W
회원 가입일: 12/21/11
1,773 평판
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 17
전체 시간: 766
