주요 콘텐츠로 건너뛰기
8BitDo Ultimate Wired Vibration/Rumble Motor Replacement
필요한 것
  1. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement, Vibration/Rumble Motor: 1 단계, 이미지 3개 중 1개 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement, Vibration/Rumble Motor: 1 단계, 이미지 3개 중 2개 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement, Vibration/Rumble Motor: 1 단계, 이미지 3개 중 3개
    • Orient the controller such that the back of the controller is facing you.
    • Insert an opening tool into the small opening on the back of the grip, and gently pry the grip cover away until it pops free.
  2. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 2 단계, 이미지 3개 중 1개 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 2 단계, 이미지 3개 중 2개 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 2 단계, 이미지 3개 중 3개
    • Pry the other grip panel off using the same method.
  3. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 3 단계, 이미지 3개 중 1개 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 3 단계, 이미지 3개 중 2개 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 3 단계, 이미지 3개 중 3개
    • Use the TR6 Torx Security screwdriver to remove the top left 10.44 mm screw on the backside.
    • Use tweezers to help you remove the screw if it does not come out with the driver.
  4. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 4 단계, 이미지 3개 중 1개 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 4 단계, 이미지 3개 중 2개 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 4 단계, 이미지 3개 중 3개
    • Use the TR6 Torx Security screwdriver to remove the middle left 10.44 mm Torx screw on the backside.
  5. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 5 단계, 이미지 3개 중 1개 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 5 단계, 이미지 3개 중 2개 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 5 단계, 이미지 3개 중 3개
    • Use the TR6 Torx Security screwdriver to remove the bottom left 10.44 mm Torx screw on the backside.
  6. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 6 단계, 이미지 3개 중 1개 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 6 단계, 이미지 3개 중 2개 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 6 단계, 이미지 3개 중 3개
    • Use the TR6 Torx Security screwdriver to remove the top right 10.44 mm Torx screw on the backside.
  7. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 7 단계, 이미지 3개 중 1개 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 7 단계, 이미지 3개 중 2개 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 7 단계, 이미지 3개 중 3개
    • Use the TR6 Torx Security screwdriver to remove the middle right 10.44 mm Torx screw on the backside.
  8. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 8 단계, 이미지 3개 중 1개 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 8 단계, 이미지 3개 중 2개 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 8 단계, 이미지 3개 중 3개
    • Use the TR6 Torx Security screwdriver to unscrew the bottom right 10.44 mm Torx screw on the backside.
  9. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 9 단계, 이미지 2개 중 1개 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 9 단계, 이미지 2개 중 2개
    • Insert an opening tool into the small opening between the front and back panels, and gently pry the back panel away to open the bottom clamps of the top panel of the controller.
  10. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 10 단계, 이미지 2개 중 1개 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 10 단계, 이미지 2개 중 2개
    • Insert an opening tool into the small opening between the front and back panel (top view) and pry away to remove the top half.
    • A ribbon cable connects the front and back portions of the controller.
  11. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 11 단계, 이미지 3개 중 1개 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 11 단계, 이미지 3개 중 2개 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 11 단계, 이미지 3개 중 3개
    • Pull the midframe free with an adequate amount of force.
  12. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 12 단계, 이미지 3개 중 1개 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 12 단계, 이미지 3개 중 2개 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 12 단계, 이미지 3개 중 3개
    • Detach the motor connector from the motherboard.
  13. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 13 단계, 이미지 2개 중 1개 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 13 단계, 이미지 2개 중 2개
    • Pull the weight out of the housing with adequate force.
  14. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 14 단계, 이미지 3개 중 1개 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 14 단계, 이미지 3개 중 2개 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: 14 단계, 이미지 3개 중 3개
    • Remove the rumble or vibration motor from the controller.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Sebrina Abubeker
회원 가입일: 02/08/24
679 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 42
전체 시간: 751
