주요 콘텐츠로 건너뛰기
AARP RealPad MA7BX2 Back Cover Replacement
필요한 것
  1. AARP RealPad MA7BX2 Back Cover Replacement, Back Cover: 1 단계, 이미지 1/2 AARP RealPad MA7BX2 Back Cover Replacement, Back Cover: 1 단계, 이미지 2/2
    • Loosen the back cover using the suction cup.
    • Pull up on the center of the back with the suction cup.
    • Pull up on all four corners of the back with the suction cup.
  2. AARP RealPad MA7BX2 Back Cover Replacement: 2 단계, 이미지 1/1
    • Remove the back cover by gently placing the small opening tool in the crevice created by loosening the back.
    • Slide the opening tool around the edges of the device.
    • Wedge it open using the opening tool.
    • Use the suction cup again if you're having trouble removing the back cover.
  3. AARP RealPad MA7BX2 Back Cover Replacement: 3 단계, 이미지 1/2 AARP RealPad MA7BX2 Back Cover Replacement: 3 단계, 이미지 2/2
    • The black tape is stuck to delicate wires; remove with caution.
    • Peel off the silver tape.
    • Gently pull off the black tape.
  4. AARP RealPad MA7BX2 Back Cover Replacement: 4 단계, 이미지 1/2 AARP RealPad MA7BX2 Back Cover Replacement: 4 단계, 이미지 2/2
    • Using a JIS #000 screwdriver, remove the two 2.5 mm screws.
  5. AARP RealPad MA7BX2 Back Cover Replacement: 5 단계, 이미지 1/2 AARP RealPad MA7BX2 Back Cover Replacement: 5 단계, 이미지 2/2
    • Lift off the black audio cover.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alana Escue
회원 가입일: 09/18/18
425 평판
안내서 3개 작성하였습니다
University of North Texas, Team S4-G7, Raign Fall 2018 University of North Texas, Team S4-G7, Raign Fall 2018 회원
UNT-RAIGN-F18S4G7
5 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 14
전체 시간: 815
