주요 콘텐츠로 건너뛰기
AARP RealPad MA7BX2 Motherboard Replacement
필요한 것
  1. AARP RealPad MA7BX2 Motherboard Replacement, Back Cover: 1 단계, 이미지 1/2 AARP RealPad MA7BX2 Motherboard Replacement, Back Cover: 1 단계, 이미지 2/2
    • Loosen the back cover using the suction cup.
    • Pull up on the center of the back with the suction cup.
    • Pull up on all four corners of the back with the suction cup.
  2. AARP RealPad MA7BX2 Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove the back cover by gently placing the small opening tool in the crevice created by loosening the back.
    • Slide the opening tool around the edges of the device.
    • Wedge it open using the opening tool.
    • Use the suction cup again if you're having trouble removing the back cover.
  3. AARP RealPad MA7BX2 Motherboard Replacement: 3 단계, 이미지 1/2 AARP RealPad MA7BX2 Motherboard Replacement: 3 단계, 이미지 2/2
    • The black tape is stuck to delicate wires; remove with caution.
    • Peel off the silver tape.
    • Gently pull off the black tape.
  4. AARP RealPad MA7BX2 Motherboard Replacement: 4 단계, 이미지 1/2 AARP RealPad MA7BX2 Motherboard Replacement: 4 단계, 이미지 2/2
    • Using a JIS #000 screwdriver, remove the two 2.5 mm screws.
  5. AARP RealPad MA7BX2 Motherboard Replacement: 5 단계, 이미지 1/2 AARP RealPad MA7BX2 Motherboard Replacement: 5 단계, 이미지 2/2
    • Lift off the black audio cover.
  6. AARP RealPad MA7BX2 Motherboard Replacement, Motherboard: 6 단계, 이미지 1/2 AARP RealPad MA7BX2 Motherboard Replacement, Motherboard: 6 단계, 이미지 2/2
    • Remove the two JIS #000 screws.
  7. AARP RealPad MA7BX2 Motherboard Replacement: 7 단계, 이미지 1/2 AARP RealPad MA7BX2 Motherboard Replacement: 7 단계, 이미지 2/2
    • Flip up the small black connectors using a spudger or your nails.
    • Be careful when flipping them up. Too much force can cause them to break.
  8. AARP RealPad MA7BX2 Motherboard Replacement: 8 단계, 이미지 1/1
    • Remove battery.
    • Removing the battery may need some force. Be careful as to not break anything.
  9. AARP RealPad MA7BX2 Motherboard Replacement: 9 단계, 이미지 1/2 AARP RealPad MA7BX2 Motherboard Replacement: 9 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use the tweezers to loosen up the sides of speakers by going into the gaps, before picking it up.
    • There are magnets holding down the speakers. Be careful as to not pick them up with the speakers.
    • The top of the speakers are very fragile and may fall out at the slightest touch. Be careful when picking them up.
  10. AARP RealPad MA7BX2 Motherboard Replacement: 10 단계, 이미지 1/2 AARP RealPad MA7BX2 Motherboard Replacement: 10 단계, 이미지 2/2
    • Remove all wire connections by sliding them out of the connectors.
    • Be careful as to not forcefully pull out anything because the wires are very delicate.
  11. AARP RealPad MA7BX2 Motherboard Replacement: 11 단계, 이미지 1/1
    • Take off the motherboard and set it aside. Your Finished product should look like this.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alana Escue
회원 가입일: 09/18/18
425 평판
안내서 3개 작성하였습니다
University of North Texas, Team S4-G7, Raign Fall 2018 University of North Texas, Team S4-G7, Raign Fall 2018 회원
UNT-RAIGN-F18S4G7
5 회원들
안내서 4개 작성하였습니다
댓글 한 개
I have a realpad that's is missing all the motherboard and do y'all know where can I take to get it fix because I got it for my sweet 15 as a gift from my uncle and aunt
Luz Hernandez - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 494
