주요 콘텐츠로 건너뛰기
AARP RealPad MA7BX2 Screen Replacement
필요한 것
  1. AARP RealPad MA7BX2 Screen Replacement, Back Cover: 1 단계, 이미지 1/2 AARP RealPad MA7BX2 Screen Replacement, Back Cover: 1 단계, 이미지 2/2
    • Loosen the back cover using the suction cup.
    • Pull up on the center of the back with the suction cup.
    • Pull up on all four corners of the back with the suction cup.
  2. AARP RealPad MA7BX2 Screen Replacement: 2 단계, 이미지 1/1
    • Remove the back cover by gently placing the small opening tool in the crevice created by loosening the back.
    • Slide the opening tool around the edges of the device.
    • Wedge it open using the opening tool.
    • Use the suction cup again if you're having trouble removing the back cover.
  3. AARP RealPad MA7BX2 Screen Replacement: 3 단계, 이미지 1/2 AARP RealPad MA7BX2 Screen Replacement: 3 단계, 이미지 2/2
    • The black tape is stuck to delicate wires; remove with caution.
    • Peel off the silver tape.
    • Gently pull off the black tape.
  4. AARP RealPad MA7BX2 Screen Replacement: 4 단계, 이미지 1/2 AARP RealPad MA7BX2 Screen Replacement: 4 단계, 이미지 2/2
    • Using a JIS #000 screwdriver, remove the two 2.5 mm screws.
  5. AARP RealPad MA7BX2 Screen Replacement: 5 단계, 이미지 1/2 AARP RealPad MA7BX2 Screen Replacement: 5 단계, 이미지 2/2
    • Lift off the black audio cover.
  6. AARP RealPad MA7BX2 Screen Replacement, Motherboard: 6 단계, 이미지 1/2 AARP RealPad MA7BX2 Screen Replacement, Motherboard: 6 단계, 이미지 2/2
    • Remove the two JIS #000 screws.
  7. AARP RealPad MA7BX2 Screen Replacement: 7 단계, 이미지 1/2 AARP RealPad MA7BX2 Screen Replacement: 7 단계, 이미지 2/2
    • Flip up the small black connectors using a spudger or your nails.
    • Be careful when flipping them up. Too much force can cause them to break.
  8. AARP RealPad MA7BX2 Screen Replacement: 8 단계, 이미지 1/1
    • Remove battery.
    • Removing the battery may need some force. Be careful as to not break anything.
  9. AARP RealPad MA7BX2 Screen Replacement: 9 단계, 이미지 1/2 AARP RealPad MA7BX2 Screen Replacement: 9 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use the tweezers to loosen up the sides of speakers by going into the gaps, before picking it up.
    • There are magnets holding down the speakers. Be careful as to not pick them up with the speakers.
    • The top of the speakers are very fragile and may fall out at the slightest touch. Be careful when picking them up.
  10. AARP RealPad MA7BX2 Screen Replacement: 10 단계, 이미지 1/2 AARP RealPad MA7BX2 Screen Replacement: 10 단계, 이미지 2/2
    • Remove all wire connections by sliding them out of the connectors.
    • Be careful as to not forcefully pull out anything because the wires are very delicate.
  11. AARP RealPad MA7BX2 Screen Replacement: 11 단계, 이미지 1/1
    • Take off the motherboard and set it aside. Your Finished product should look like this.
  12. AARP RealPad MA7BX2 Screen Replacement, Screen: 12 단계, 이미지 1/3 AARP RealPad MA7BX2 Screen Replacement, Screen: 12 단계, 이미지 2/3 AARP RealPad MA7BX2 Screen Replacement, Screen: 12 단계, 이미지 3/3
    • Use the suction cup to loosen and pull up the screen.
    • Be careful when pulling up screen. Too much force can lead to you breaking it.
결론
Alana Escue
회원 가입일: 09/18/18
425 평판
안내서 3개 작성하였습니다
University of North Texas, Team S4-G7, Raign Fall 2018 University of North Texas, Team S4-G7, Raign Fall 2018 회원
UNT-RAIGN-F18S4G7
5 회원들
안내서 4개 작성하였습니다
댓글 한 개
Remember to give the lengths for all screws. For warnings, try to be more straight forward and try not to use words like '“note.” Remember to add an introduction.
Jackson Reynolds - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 13
전체 시간: 525
