주요 콘텐츠로 건너뛰기
ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement
필요한 것
  1. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Flip your laptop over so the back panel is facing upwards.
    • Locate the lock switch below the battery.
  2. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 2 단계, 이미지 3개 중 1개 ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 2 단계, 이미지 3개 중 2개 ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 2 단계, 이미지 3개 중 3개
    • Slide the lock switch to the right using your finger or a spudger.
    • At the same time, grasp the battery with your other hand and slide it out of the laptop.
    • Remove the battery.
    • To reinsert or replace the battery, simply line up the tabs on the battery with the laptop and slide it straight back in. There is no need to move the lock switch.
  3. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement, Hard Drive (HDD): 3 단계, 이미지 1개 중 1개
    • Unscrew the one 8mm Phillips #0 screw from the bottom panel.
  4. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 4 단계, 이미지 3개 중 1개 ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 4 단계, 이미지 3개 중 2개 ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the back panel by carefully disengaging it around the edges and then pulling upwards.
  5. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the other 8mm Phillips #0 screw holding the hard drive to the rest of the laptop.
  6. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 6 단계, 이미지 2개 중 1개 ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 6 단계, 이미지 2개 중 2개
    • Slide the hard drive to the left using a plastic opening tool.
  7. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 7 단계, 이미지 3개 중 1개 ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 7 단계, 이미지 3개 중 2개 ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 7 단계, 이미지 3개 중 3개
    • To remove the hard drive, pull up and to the left using the plastic tab as shown on the left side of the hard drive.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Cody Lim
회원 가입일: 01/25/17
1,533 평판
안내서 7개를 작성함
Cal Poly, Team 9-6, Banghart Winter 2017 Cal Poly, Team 9-6, Banghart Winter 2017 회원
CPSU-BANGHART-W17S9G6
3 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 22
전체 시간: 3,873
