주요 콘텐츠로 건너뛰기
ACER Aspire E1-572-6870 Keyboard Replacement
필요한 것
  1. ACER Aspire E1-572-6870 Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Flip your laptop over so the back panel is facing upwards.
    • Locate the lock switch below the battery.
  2. ACER Aspire E1-572-6870 Keyboard Replacement: 2 단계, 이미지 3개 중 1개 ACER Aspire E1-572-6870 Keyboard Replacement: 2 단계, 이미지 3개 중 2개 ACER Aspire E1-572-6870 Keyboard Replacement: 2 단계, 이미지 3개 중 3개
    • Slide the lock switch to the right using your finger or a spudger.
    • At the same time, grasp the battery with your other hand and slide it out of the laptop.
    • Remove the battery.
    • To reinsert or replace the battery, simply line up the tabs on the battery with the laptop and slide it straight back in. There is no need to move the lock switch.
  3. ACER Aspire E1-572-6870 Keyboard Replacement, Back Panel: 3 단계, 이미지 2개 중 1개 ACER Aspire E1-572-6870 Keyboard Replacement, Back Panel: 3 단계, 이미지 2개 중 2개
    • Remove the 16 2.5 x 8mm Phillips #0 screws from the back panel.
  4. ACER Aspire E1-572-6870 Keyboard Replacement: 4 단계, 이미지 3개 중 1개 ACER Aspire E1-572-6870 Keyboard Replacement: 4 단계, 이미지 3개 중 2개 ACER Aspire E1-572-6870 Keyboard Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the back panel by carefully disengaging it around the edges and then pull upwards.
  5. ACER Aspire E1-572-6870 Keyboard Replacement: 5 단계, 이미지 1개 중 1개
    • Unscrew the two remaining 2.5 x 8mm Phillips #0 screws from inside the bottom panel as designated in the image.
  6. ACER Aspire E1-572-6870 Keyboard Replacement: 6 단계, 이미지 2개 중 1개 ACER Aspire E1-572-6870 Keyboard Replacement: 6 단계, 이미지 2개 중 2개
    • Slide out the plastic insert located on the left side, and remove, before returning the laptop to the face-up position.
  7. ACER Aspire E1-572-6870 Keyboard Replacement: 7 단계, 이미지 3개 중 1개 ACER Aspire E1-572-6870 Keyboard Replacement: 7 단계, 이미지 3개 중 2개 ACER Aspire E1-572-6870 Keyboard Replacement: 7 단계, 이미지 3개 중 3개
    • Carefully flip your laptop back over and open it up.
  8. ACER Aspire E1-572-6870 Keyboard Replacement: 8 단계, 이미지 3개 중 1개 ACER Aspire E1-572-6870 Keyboard Replacement: 8 단계, 이미지 3개 중 2개 ACER Aspire E1-572-6870 Keyboard Replacement: 8 단계, 이미지 3개 중 3개
    • Carefully detach the top panel of the laptop and slowly lift it up to reveal the internal components.
  9. ACER Aspire E1-572-6870 Keyboard Replacement: 9 단계, 이미지 2개 중 1개 ACER Aspire E1-572-6870 Keyboard Replacement: 9 단계, 이미지 2개 중 2개
    • Locate the three ribbons that need to be unplugged, so the two halves of the device may be separated.
    • Unplug the large ribbon by sliding the retainer clip backward (toward the hinges), then gently pulling the cable out of the connector.
  10. ACER Aspire E1-572-6870 Keyboard Replacement: 10 단계, 이미지 3개 중 1개 ACER Aspire E1-572-6870 Keyboard Replacement: 10 단계, 이미지 3개 중 2개 ACER Aspire E1-572-6870 Keyboard Replacement: 10 단계, 이미지 3개 중 3개
    • Remove the other two smaller ribbons by flipping open the small plastic tab that holds the ribbon in the connector.
    • Then simply pull the free ribbon out.
  11. ACER Aspire E1-572-6870 Keyboard Replacement: 11 단계, 이미지 2개 중 1개 ACER Aspire E1-572-6870 Keyboard Replacement: 11 단계, 이미지 2개 중 2개
    • Lift the top panel all the way up and your laptop is now split into its two distinct halves.
  12. ACER Aspire E1-572-6870 Keyboard Replacement, Keyboard: 12 단계, 이미지 3개 중 1개 ACER Aspire E1-572-6870 Keyboard Replacement, Keyboard: 12 단계, 이미지 3개 중 2개 ACER Aspire E1-572-6870 Keyboard Replacement, Keyboard: 12 단계, 이미지 3개 중 3개
    • Separate the top panel from the rest of the laptop.
    • Remove the yellow tape and then remove the three 1.4 x 2 mm Phillips #00 screws with a Phillips #00 screwdriver.
  13. ACER Aspire E1-572-6870 Keyboard Replacement: 13 단계, 이미지 3개 중 1개 ACER Aspire E1-572-6870 Keyboard Replacement: 13 단계, 이미지 3개 중 2개 ACER Aspire E1-572-6870 Keyboard Replacement: 13 단계, 이미지 3개 중 3개
    • Remove the clear tape and then, remove the six 1.6 x 3 mm Phillips #0 screws with a Phillips #0 screwdriver.
  14. ACER Aspire E1-572-6870 Keyboard Replacement: 14 단계, 이미지 3개 중 1개 ACER Aspire E1-572-6870 Keyboard Replacement: 14 단계, 이미지 3개 중 2개 ACER Aspire E1-572-6870 Keyboard Replacement: 14 단계, 이미지 3개 중 3개
    • Once the screws have all been removed, use a plastic opening tool to slide the metal panel upward on both sides to disengage the metal tabs.
    • Flip the metal panel out once this is done.
  15. ACER Aspire E1-572-6870 Keyboard Replacement: 15 단계, 이미지 3개 중 1개 ACER Aspire E1-572-6870 Keyboard Replacement: 15 단계, 이미지 3개 중 2개 ACER Aspire E1-572-6870 Keyboard Replacement: 15 단계, 이미지 3개 중 3개
    • Flip panel towards you to take out keyboard.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Cody Lim
회원 가입일: 01/25/17
1,533 평판
안내서 7개를 작성함
Cal Poly, Team 9-6, Banghart Winter 2017 Cal Poly, Team 9-6, Banghart Winter 2017 회원
CPSU-BANGHART-W17S9G6
3 회원들
안내서 7개를 작성함
1가이드 댓글
If installing a new keyboard, remember to pull the keyboard cable through the metal panel before screwing it back in.
Jared Williams - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 26
전체 시간: 2,135
