주요 콘텐츠로 건너뛰기
ACER Aspire E1-572-6870 RAM Replacement
필요한 것
  1. ACER Aspire E1-572-6870 RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Flip your laptop over so the back panel is facing upwards.
    • Locate the lock switch below the battery.
  2. ACER Aspire E1-572-6870 RAM Replacement: 2 단계, 이미지 1/3 ACER Aspire E1-572-6870 RAM Replacement: 2 단계, 이미지 2/3 ACER Aspire E1-572-6870 RAM Replacement: 2 단계, 이미지 3/3
    • Slide the lock switch to the right using your finger or a spudger.
    • At the same time, grasp the battery with your other hand and slide it out of the laptop.
    • Remove the battery.
    • To reinsert or replace the battery, simply line up the tabs on the battery with the laptop and slide it straight back in. There is no need to move the lock switch.
  3. ACER Aspire E1-572-6870 RAM Replacement, RAM: 3 단계, 이미지 1/1
    • Unscrew the one 2.5 x 8mm Phillips #0 screw from the bottom panel as designated in the image.
  4. ACER Aspire E1-572-6870 RAM Replacement: 4 단계, 이미지 1/3 ACER Aspire E1-572-6870 RAM Replacement: 4 단계, 이미지 2/3 ACER Aspire E1-572-6870 RAM Replacement: 4 단계, 이미지 3/3
    • Remove the back panel by carefully disengaging it around the edges and then pull upwards.
  5. ACER Aspire E1-572-6870 RAM Replacement: 5 단계, 이미지 1/3 ACER Aspire E1-572-6870 RAM Replacement: 5 단계, 이미지 2/3 ACER Aspire E1-572-6870 RAM Replacement: 5 단계, 이미지 3/3
    • Disengage the metal tabs located on either side of the RAM stick by pulling the tabs outward.
    • Carefully remove the RAM so you don't damage the connectors.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Cody Lim
회원 가입일: 01/25/17
1,404 평판
안내서 7개 작성하였습니다
Cal Poly, Team 9-6, Banghart Winter 2017 Cal Poly, Team 9-6, Banghart Winter 2017 회원
CPSU-BANGHART-W17S9G6
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 7
전체 시간: 963
