주요 콘텐츠로 건너뛰기
ACER Aspire V5-571P-6609 Display Replacement
필요한 것
  1. ACER Aspire V5-571P-6609 Display Replacement, Display Replacement: 1 단계, 이미지 1개 중 1개
    • Start by placing laptop on non-static surface and powering off completely. Apply static resistant wristband.
  2. ACER Aspire V5-571P-6609 Display Replacement: 2 단계, 이미지 3개 중 1개 ACER Aspire V5-571P-6609 Display Replacement: 2 단계, 이미지 3개 중 2개 ACER Aspire V5-571P-6609 Display Replacement: 2 단계, 이미지 3개 중 3개
    • Use a pointed tool (we used a screwdriver) to slide release to the right when facing laptop from non-battery side.
    • Gently pull battery away from laptop with slide release held open.
  3. ACER Aspire V5-571P-6609 Display Replacement: 3 단계, 이미지 2개 중 1개 ACER Aspire V5-571P-6609 Display Replacement: 3 단계, 이미지 2개 중 2개
    • Remove all twenty 6.7 mm Phillips #0 screws from the bottom side of the laptop.
    • Turn the laptop over and open the lid.
  4. ACER Aspire V5-571P-6609 Display Replacement: 4 단계, 이미지 3개 중 1개 ACER Aspire V5-571P-6609 Display Replacement: 4 단계, 이미지 3개 중 2개 ACER Aspire V5-571P-6609 Display Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a Jimmy tool to slide between the keyboard and top panel. Gently pop the tabs out of their slots and the keyboard will come loose. DO NOT PULL KEYBOARD OUT YET.
    • Before you lift the keyboard out of place, note the two flat flex cables for the key input and keyboard backlights. One is larger that the other. Lift keyboard just high enough to gently release them from the two ports seen here with a non-static tweezers.
    • Once cables are safely detached, lift keyboard off of laptop and place on safe, non-static surface.
  5. ACER Aspire V5-571P-6609 Display Replacement: 5 단계, 이미지 3개 중 1개 ACER Aspire V5-571P-6609 Display Replacement: 5 단계, 이미지 3개 중 2개 ACER Aspire V5-571P-6609 Display Replacement: 5 단계, 이미지 3개 중 3개
    • Use a Phillips #0 screwdriver to remove the six screws.
    • Flip up the block lock bars on the two ZIF connectors, then gently disconnect the two ribbon cables.
  6. ACER Aspire V5-571P-6609 Display Replacement: 6 단계, 이미지 3개 중 1개 ACER Aspire V5-571P-6609 Display Replacement: 6 단계, 이미지 3개 중 2개 ACER Aspire V5-571P-6609 Display Replacement: 6 단계, 이미지 3개 중 3개
    • Slide the Jimmy Tool in between front and back panel of the laptop.
    • Slowly rotate the Jimmy tool, prying until the top panel pops loose. Repeat on all sides until the top panel is free of main body.
    • Gently lift top panel free of main body. You now have access to the Motherboard.
  7. ACER Aspire V5-571P-6609 Display Replacement: 7 단계, 이미지 3개 중 1개 ACER Aspire V5-571P-6609 Display Replacement: 7 단계, 이미지 3개 중 2개 ACER Aspire V5-571P-6609 Display Replacement: 7 단계, 이미지 3개 중 3개
    • Once the top panel is removed, lift the tape that holds the power cable for the fan.
    • Gently pull fan power cable out.
    • Use tweezers to gently pull charging port out of place.
  8. ACER Aspire V5-571P-6609 Display Replacement: 8 단계, 이미지 3개 중 1개 ACER Aspire V5-571P-6609 Display Replacement: 8 단계, 이미지 3개 중 2개 ACER Aspire V5-571P-6609 Display Replacement: 8 단계, 이미지 3개 중 3개
    • Use tweezers to gently detach black and white Wi-Fi card cables shown here by lifting up until they pop off.
    • Once both cables are detached, unscrew the single screw holding Wireless LAN card in place.
    • The Wi-Fi card should lift up slightly on its own. Use tweezers to gently lift the Wi-Fi card out at a 45 degree angle to prevent damage.
  9. ACER Aspire V5-571P-6609 Display Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the two Phillips #0 screws that hold in the battery port.
  10. ACER Aspire V5-571P-6609 Display Replacement: 10 단계, 이미지 1개 중 1개
    • Gently pull the optical drive out.
    • This should slide out easily by gently sliding the disc drive outwards on its rails.
  11. ACER Aspire V5-571P-6609 Display Replacement: 11 단계, 이미지 3개 중 1개 ACER Aspire V5-571P-6609 Display Replacement: 11 단계, 이미지 3개 중 2개 ACER Aspire V5-571P-6609 Display Replacement: 11 단계, 이미지 3개 중 3개
    • Place fingertips on edges of motherboard to prevent damage to the circuitry.
    • Remember to disconnect this RAM cable on the bottom of the laptop. This can also be accessed and disconnected from the RAM ports on the backside.
    • Using your fingertips, grip the edges of the motherboard to prevent damage to the circuitry.
    • The motherboard should lift out easily.
  12. ACER Aspire V5-571P-6609 Display Replacement: 12 단계, 이미지 3개 중 1개 ACER Aspire V5-571P-6609 Display Replacement: 12 단계, 이미지 3개 중 2개 ACER Aspire V5-571P-6609 Display Replacement: 12 단계, 이미지 3개 중 3개
    • Use tweezers to gently lift the tape holding down the white cable until tape is unstuck. Unthread black and white cables until free of the bottom panel.
    • Unscrew the Phillips #0 left side screws until left side of display is now lose.
    • Do the same for the two flat screws on the right side.
  13. ACER Aspire V5-571P-6609 Display Replacement: 13 단계, 이미지 1개 중 1개
    • Display should now lift free of the main body of the Laptop.
    • Safely dispose of broken display and replace with new display.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Kevin Sipple
회원 가입일: 08/25/22
355 평판
안내서 2개를 작성함
Gateway, Team 1-1, Pee Fall 2022 Gateway, Team 1-1, Pee Fall 2022 회원
GCC-PEE-F22S1G1
4 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 16
지난 30일: 36
전체 시간: 307
