주요 콘텐츠로 건너뛰기
ACER Aspire V5-571P-6609 Touchpad Replacement
필요한 것
  1. ACER Aspire V5-571P-6609 Touchpad Replacement, Touchpad: 1 단계, 이미지 1/3 ACER Aspire V5-571P-6609 Touchpad Replacement, Touchpad: 1 단계, 이미지 2/3 ACER Aspire V5-571P-6609 Touchpad Replacement, Touchpad: 1 단계, 이미지 3/3
    • Close the laptop and flip over. Locate battery slide release. This guide marks the location with a red circle.
    • Use a pointed tool (we used a screwdriver) to slide release to the right when facing the laptop from the non-battery side.
    • Gently pull the battery away from the laptop with the slide release held open.
  2. ACER Aspire V5-571P-6609 Touchpad Replacement: 2 단계, 이미지 1/1
    • Remove the two Phillips #0 screws.
    • Once all necessary screws are removed, turn the laptop over and open it.
  3. ACER Aspire V5-571P-6609 Touchpad Replacement: 3 단계, 이미지 1/3 ACER Aspire V5-571P-6609 Touchpad Replacement: 3 단계, 이미지 2/3 ACER Aspire V5-571P-6609 Touchpad Replacement: 3 단계, 이미지 3/3
    • Slide a Jimmy tool between the top of the keyboard and the outer panel, then gently pop the top tabs out of place.
    • Carefully detach the two flex cables before fully lifting keyboard out in order to avoid cable damage.
    • Once cables are safely detached, lift the keyboard off of the laptop and place it on a safe, non-static surface.
  4. ACER Aspire V5-571P-6609 Touchpad Replacement: 4 단계, 이미지 1/3 ACER Aspire V5-571P-6609 Touchpad Replacement: 4 단계, 이미지 2/3 ACER Aspire V5-571P-6609 Touchpad Replacement: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Remove the six Phillips #0 screws.
    • Flip up the plastic lock bar mechanism securing the two ribbon cables.
    • Gently pull the cables out of their ports with tweezers.
  5. ACER Aspire V5-571P-6609 Touchpad Replacement: 5 단계, 이미지 1/3 ACER Aspire V5-571P-6609 Touchpad Replacement: 5 단계, 이미지 2/3 ACER Aspire V5-571P-6609 Touchpad Replacement: 5 단계, 이미지 3/3
    • Slide a Jimmy in between the front and back panel of the laptop
    • Slowly rotate the Jimmy tool in hand until the top panel pops loose. Repeat on all sides until the top panel is free of the main body.
    • Gently lift the top panel free of the main body.
  6. ACER Aspire V5-571P-6609 Touchpad Replacement: 6 단계, 이미지 1/3 ACER Aspire V5-571P-6609 Touchpad Replacement: 6 단계, 이미지 2/3 ACER Aspire V5-571P-6609 Touchpad Replacement: 6 단계, 이미지 3/3
    • Flip the top panel over and locate the touchpad.
    • Flip up the connector's lock bar from the touchpad, then disconnect the cable.
    • Peel down the adhesive tape securing the touchpad and remove the three Phillips #0 screws securing the touchpad.
  7. ACER Aspire V5-571P-6609 Touchpad Replacement: 7 단계, 이미지 1/3 ACER Aspire V5-571P-6609 Touchpad Replacement: 7 단계, 이미지 2/3 ACER Aspire V5-571P-6609 Touchpad Replacement: 7 단계, 이미지 3/3
    • Once screws have been removed, place fingers under and over the touchpad and slowly push it up; firmly hold the touchpad as it is being removed.
    • Replace the touch pad with a new touchpad.
결론
Ernesto Pacheco
회원 가입일: 10/25/22
277 평판
안내서 2개 작성하였습니다
Gateway, Team 1-1, Pee Fall 2022 Gateway, Team 1-1, Pee Fall 2022 회원
GCC-PEE-F22S1G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 14
전체 시간: 183
