주요 콘텐츠로 건너뛰기
ACN Iris WG4K Key Pad Replacement
필요한 것
  1. ACN Iris WG4K Key Pad Replacement, Handset: 1 단계, 이미지 1/2 ACN Iris WG4K Key Pad Replacement, Handset: 1 단계, 이미지 2/2
    • Press upwards with your index finger on the 4P4C connector as shown in the image.
    • Pull the connector gently out of its socket.
  2. ACN Iris WG4K Key Pad Replacement, Lower Case: 2 단계, 이미지 1/1
    • Flip the main body of the video phone so that the bottom is facing up.
    • Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm) highlighted by the red circles.
  3. ACN Iris WG4K Key Pad Replacement: 3 단계, 이미지 1/2 ACN Iris WG4K Key Pad Replacement: 3 단계, 이미지 2/2
    • Lift the back case upwards to expose the inside components.
    • Red rectangles indicate the three ribbon cables.
    • The orange square indicates the blade connector.
  4. ACN Iris WG4K Key Pad Replacement: 4 단계, 이미지 1/3 ACN Iris WG4K Key Pad Replacement: 4 단계, 이미지 2/3 ACN Iris WG4K Key Pad Replacement: 4 단계, 이미지 3/3
    • Disconnect the three ribbon cables from their insulation-displacement connectors by flipping up the black plastic clip.
    • Gently pull the ribbon cables out of their insulation-displacement connectors.
  5. ACN Iris WG4K Key Pad Replacement: 5 단계, 이미지 1/2 ACN Iris WG4K Key Pad Replacement: 5 단계, 이미지 2/2
    • Disconnect the blade connector from the blade receptacle by gripping the exposed area of the blade connector.
    • Gently pull the blade connector out of the blade receptacle.
  6. ACN Iris WG4K Key Pad Replacement: 6 단계, 이미지 1/1
    • Gently lift up the lower case to separate it from the top case.
  7. ACN Iris WG4K Key Pad Replacement, Key Pad: 7 단계, 이미지 1/1
    • Use the Phillips #0 Screwdriver to remove the four Phillips head screws 6 mm highlighted by the red circles.
  8. ACN Iris WG4K Key Pad Replacement: 8 단계, 이미지 1/1
    • Gently lift up on the top case to separate it from the keypad/speaker panel.
  9. ACN Iris WG4K Key Pad Replacement: 9 단계, 이미지 1/2 ACN Iris WG4K Key Pad Replacement: 9 단계, 이미지 2/2
    • Disconnect the two white 2-pin JST connectors from the keypad/speaker circuit board by tugging gently until they are released.
  10. ACN Iris WG4K Key Pad Replacement: 10 단계, 이미지 1/1
    • Use the Philips screw driver to remove the four Phillips head screws 6 mm highlighted by the red circles.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Itze Kenney
회원 가입일: 02/14/17
1,066 평판
안내서 9개 작성하였습니다
USF Tampa, Team 20-4, Remmell Spring 2017 USF Tampa, Team 20-4, Remmell Spring 2017 회원
USFT-REMMELL-S17S20G4
4 회원들
안내서 20개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 168
