소개
The lower case contains the main motherboard of the ACN Iris WG4K. It is an important component because it protects the inside of the device. If it becomes badly damaged, this guide will help you replace it.
필요한 것
Press upwards with your index finger on the 4P4C connector as shown in the image.
Pull the connector gently out of its socket.
Flip the main body of the video phone so that the bottom is facing up.
Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm) highlighted by the red circles.
다른 한 분이 해당 안내서를 완성하였습니다.
