소개
The Iris WG4K's motherboard is housed within the lower case of the device. The motherboard contains parts necessary for powering the device and connecting the device to local networks via ports.
필요한 것
Press upwards with your index finger on the 4P4C connector as shown in the image.
Pull the connector gently out of its socket.
Flip the main body of the video phone so that the bottom is facing up.
Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm) highlighted by the red circles.
