소개
The speakers are necessary for audio communication while using the video phone's video call function. The speakers are not necessary for calls that do not involve video.
필요한 것
Press upwards with your index finger on the 4P4C connector as shown in the image.
Pull the connector gently out of its socket.
Flip the main body of the video phone so that the bottom is facing up.
Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm) highlighted by the red circles.
Disconnect the two white 2-pin JST connectors from the keypad/speaker circuit board by tugging gently until they release.
다른 한 분이 해당 안내서를 완성하였습니다.
