주요 콘텐츠로 건너뛰기
ACN Iris WG4K Video Camera Replacement
필요한 것
  1. ACN Iris WG4K Video Camera Replacement, Handset: 1 단계, 이미지 2개 중 1개 ACN Iris WG4K Video Camera Replacement, Handset: 1 단계, 이미지 2개 중 2개
    • Press upwards with your index finger on the 4P4C connector as shown in the image.
    • Pull the connector gently out of its socket.
  2. ACN Iris WG4K Video Camera Replacement, Lower Case: 2 단계, 이미지 1개 중 1개
    • Flip the main body of the video phone so that the bottom is facing up.
    • Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm) highlighted by the red circles.
  3. ACN Iris WG4K Video Camera Replacement: 3 단계, 이미지 2개 중 1개 ACN Iris WG4K Video Camera Replacement: 3 단계, 이미지 2개 중 2개
    • Lift the back case upwards to expose the inside components.
    • Red rectangles indicate the three ribbon cables.
    • The orange square indicates the blade connector.
  4. ACN Iris WG4K Video Camera Replacement: 4 단계, 이미지 3개 중 1개 ACN Iris WG4K Video Camera Replacement: 4 단계, 이미지 3개 중 2개 ACN Iris WG4K Video Camera Replacement: 4 단계, 이미지 3개 중 3개
    • Disconnect the three ribbon cables from their insulation-displacement connectors by flipping up the black plastic clip.
    • Gently pull the ribbon cables out of their insulation-displacement connectors.
  5. ACN Iris WG4K Video Camera Replacement: 5 단계, 이미지 2개 중 1개 ACN Iris WG4K Video Camera Replacement: 5 단계, 이미지 2개 중 2개
    • Disconnect the blade connector from the blade receptacle by gripping the exposed area of the blade connector.
    • Gently pull the blade connector out of the blade receptacle.
  6. ACN Iris WG4K Video Camera Replacement: 6 단계, 이미지 1개 중 1개
    • Gently lift up the lower case to separate it from the top case.
  7. ACN Iris WG4K Video Camera Replacement, Blade Connector: 7 단계, 이미지 1개 중 1개
  8. ACN Iris WG4K Video Camera Replacement: 8 단계, 이미지 1개 중 1개
    • Gently lift up on the upper case to separate it from the keypad/speaker panel.
  9. ACN Iris WG4K Video Camera Replacement: 9 단계, 이미지 1개 중 1개
    • Use the Phillips #0 Screwdriver to remove the two Phillips head screws (5 mm) located on the upper case.
  10. ACN Iris WG4K Video Camera Replacement: 10 단계, 이미지 1개 중 1개
    • Rotate the top case 180 degrees so that the video screen is closest to you.
    • Lift up the bottom up so that it is perpendicular to the table (this helps you reach the two top screws).
    • The four Phillips head screws (6 mm) are highlighted by the red circles.
  11. ACN Iris WG4K Video Camera Replacement: 11 단계, 이미지 1개 중 1개
    • Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm).
  12. ACN Iris WG4K Video Camera Replacement: 12 단계, 이미지 1개 중 1개
    • Flip the top case so that the video screen is facing up.
  13. ACN Iris WG4K Video Camera Replacement: 13 단계, 이미지 1개 중 1개
    • Rotate the top case 180 degrees.
    • Gently lift up on the video screen and the blade and ribbon connector to give you more slack to work with.
  14. ACN Iris WG4K Video Camera Replacement: 14 단계, 이미지 1개 중 1개
    • Place the video screen face down to expose the two screws. The screws are indicated by the red circles.
  15. ACN Iris WG4K Video Camera Replacement: 15 단계, 이미지 2개 중 1개 ACN Iris WG4K Video Camera Replacement: 15 단계, 이미지 2개 중 2개
    • Use the Phillips #0 Screwdriver to remove the two Phillips head screws (6 mm)
  16. ACN Iris WG4K Video Camera Replacement: 16 단계, 이미지 2개 중 1개 ACN Iris WG4K Video Camera Replacement: 16 단계, 이미지 2개 중 2개
    • Pull the ribbon connector and blade connector through the top case.
  17. ACN Iris WG4K Video Camera Replacement, Video Screen Ribbon Cable: 17 단계, 이미지 1개 중 1개
    • Note that the video screen is no longer attached to the top case, place in on a flat surface.
    • Gently lift of the silver casing.
  18. ACN Iris WG4K Video Camera Replacement: 18 단계, 이미지 3개 중 1개 ACN Iris WG4K Video Camera Replacement: 18 단계, 이미지 3개 중 2개 ACN Iris WG4K Video Camera Replacement: 18 단계, 이미지 3개 중 3개
    • The two ribbon connectors are indicated by the red rectangles.
    • Disconnect the two ribbon cables from their insulation-displacement connectors by flipping up the black plastic clip.
    • Gently pull out the ribbon cables. Gently pull out the ribbon cables.
  19. ACN Iris WG4K Video Camera Replacement, Video Screen: 19 단계, 이미지 1개 중 1개
    • Gently lift the video screen out of its case.
  20. ACN Iris WG4K Video Camera Replacement, Video Camera: 20 단계, 이미지 3개 중 1개 ACN Iris WG4K Video Camera Replacement, Video Camera: 20 단계, 이미지 3개 중 2개 ACN Iris WG4K Video Camera Replacement, Video Camera: 20 단계, 이미지 3개 중 3개
    • Flip the video screen over so that the screen itself is face-down on a flat surface to expose the camera.
    • Push up on the two clips located on the right and left side of the video camera simultaneously.
    • Gently pull the camera out.
결론
작성자
2다른 기여자 명과 함께
Itze Kenney
회원 가입일: 02/14/17
1,066 평판
안내서 9개를 작성함
USF Tampa, Team 20-4, Remmell Spring 2017 USF Tampa, Team 20-4, Remmell Spring 2017 회원
USFT-REMMELL-S17S20G4
4 회원들
안내서 20개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 307
