주요 콘텐츠로 건너뛰기
AEE Mach 1 Battery Replacement
  1. AEE Mach 1 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure that your device is powered off before doing any work.
    • The battery is located at the back of the drone, on the opposite end of the drone from the camera.
    • There are two tabs on the edge of each side of the battery.
  2. AEE Mach 1 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • To remove the battery, simply grip the battery by the tabs, press down on both tabs, and pull the battery out.
  3. AEE Mach 1 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • To replace the battery, simply slide it back into its place until the tabs click back into place. If you are having trouble doing this, you may be putting it in upside down. Try flipping it over and trying again.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Patrick Lewis
회원 가입일: 09/04/19
382 평판
안내서 2개를 작성함
2가이드 댓글
purchase the aee mach 1 but it has no battery
Ulysses aka UL Salett - 답글
How do I get a new battery where do I look
haroldlknight55 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 39
전체 시간: 1,201
