주요 콘텐츠로 건너뛰기
AEE Mach 1 Camera Replacement
필요한 것
  1. AEE Mach 1 Camera Replacement, Camera: 1 단계, 이미지 1개 중 1개
    • Take out the AEE Mach 1 and place it on a surface with its propellers facing up.
  2. AEE Mach 1 Camera Replacement: 2 단계, 이미지 2개 중 1개 AEE Mach 1 Camera Replacement: 2 단계, 이미지 2개 중 2개
    • Holding the base of a propeller with one hand, unscrew the propeller by hand in a clockwise direction. Complete this action on all 4 propellers.
  3. AEE Mach 1 Camera Replacement: 3 단계, 이미지 2개 중 1개 AEE Mach 1 Camera Replacement: 3 단계, 이미지 2개 중 2개
    • Flip the AEE Mach 1 upside down.
    • Remove the screws on the drone's arms using a Torx T5 screwdriver.
  4. AEE Mach 1 Camera Replacement: 4 단계, 이미지 2개 중 1개 AEE Mach 1 Camera Replacement: 4 단계, 이미지 2개 중 2개
    • Gently pry open the top panel of the drone using a spudger.
    • Do not completely remove the panel, as there will still be wired connections between the two halves.
    • Rotate the top panel slightly to reveal the four screws beneath each propellor arm.
    • Remove each of the four screws with a Phillips #0 screwdriver.
    • Lift off the top panel, as it should now be free from the rest of the device.
  5. AEE Mach 1 Camera Replacement: 5 단계, 이미지 1개 중 1개
    • Using a Phillips #00 screwdriver, remove the screws from the four corners of the inner white chassis.
  6. AEE Mach 1 Camera Replacement: 6 단계, 이미지 2개 중 1개 AEE Mach 1 Camera Replacement: 6 단계, 이미지 2개 중 2개
    • Using a Spudger (or similar tool to scrap/pry with), remove the copper foil used as tape from the sides of the chassis.
    • Remove the small metal covering from the side boards.
    • This can be done by hand or with the assistance of a prying tool.
  7. AEE Mach 1 Camera Replacement: 7 단계, 이미지 2개 중 1개 AEE Mach 1 Camera Replacement: 7 단계, 이미지 2개 중 2개
    • Using a Phillips #00 screwdriver, remove the four screws separating the side board from the white chassis.
  8. AEE Mach 1 Camera Replacement: 8 단계, 이미지 2개 중 1개 AEE Mach 1 Camera Replacement: 8 단계, 이미지 2개 중 2개
    • Using a Phillips #00 screwdriver, remove the four screws from the large motherboard on the white chassis.
    • Lift the motherboard out of the case, revealing the camera cable.
  9. AEE Mach 1 Camera Replacement: 9 단계, 이미지 3개 중 1개 AEE Mach 1 Camera Replacement: 9 단계, 이미지 3개 중 2개 AEE Mach 1 Camera Replacement: 9 단계, 이미지 3개 중 3개
    • Using the Phillips #00 screwdriver, remove the four screws holding the camera mechanism in place.
    • Lift the camera assembly out of the case.
결론
작성자
4다른 기여자 명과 함께
Cameron C Blanchard
회원 가입일: 09/16/20
524 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 26
전체 시간: 540
