주요 콘텐츠로 건너뛰기
AEG Electrolux FM72 Disassembly for cleaning
필요한 것
  1. AEG Electrolux FM72 Disassembly for cleaning, Opening the Device: 1 단계, 이미지 1/3 AEG Electrolux FM72 Disassembly for cleaning, Opening the Device: 1 단계, 이미지 2/3 AEG Electrolux FM72 Disassembly for cleaning, Opening the Device: 1 단계, 이미지 3/3
    • Open the lid by pressing the grey button and lifting it away.
    • Clean each of the plastic parts with soap and water, and then leave them out to dry.
  2. AEG Electrolux FM72 Disassembly for cleaning, Opening the Electronic Case: 2 단계, 이미지 1/3 AEG Electrolux FM72 Disassembly for cleaning, Opening the Electronic Case: 2 단계, 이미지 2/3 AEG Electrolux FM72 Disassembly for cleaning, Opening the Electronic Case: 2 단계, 이미지 3/3
    • Follow these steps to open the electronic casing.
    • Remove the four screws as shown in picture two.
    • A long Phillips screwdriver is needed for step two.
    • Remove the fifth screw at the bottom as shown in picture three.
  3. AEG Electrolux FM72 Disassembly for cleaning: 3 단계, 이미지 1/3 AEG Electrolux FM72 Disassembly for cleaning: 3 단계, 이미지 2/3 AEG Electrolux FM72 Disassembly for cleaning: 3 단계, 이미지 3/3
    • Gently pry the device open, using an iSesamo opener.
    • Now the I/O button can be removed.
    • Completely replacing this entire part requires desoldering wire connections.
  4. AEG Electrolux FM72 Disassembly for cleaning, cleaning electronics: 4 단계, 이미지 1/2 AEG Electrolux FM72 Disassembly for cleaning, cleaning electronics: 4 단계, 이미지 2/2
    • Now the electronic components can be cleaned using an air compressor.
    • In picture one, you can see the PCBs. Under the PCB, you'll see blue batteries. These are 2 x 3 AA rechargeable batteries .
    • If the dust bag needs to be replaced, remove its securing screws.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Kevin D
회원 가입일: 05/02/14
7,294 평판
안내서 21개 작성하였습니다
댓글 3개
Hello
How can i repair the electric wire on this device please ?
Heloise - 답글
Hallo
Which electric wire do you mean? Can you send in a picture? Does it need soldering?
Kind regards
Kevin
Kevin D - 답글
How can I disassemble the motor parts for cleaning?
wongkapo0611 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 42
전체 시간: 6,518
