주요 콘텐츠로 건너뛰기
AEG LM6000-U Lavazza A Modo Mio Disassembly
필요한 것
  1. AEG LM6000-U  Lavazza A Modo Mio Disassembly, INtroduction: 1 단계, 이미지 2개 중 1개 AEG LM6000-U  Lavazza A Modo Mio Disassembly, INtroduction: 1 단계, 이미지 2개 중 2개
    • This guide is about taking apart this coffee maker. In my case the water flow stopped after running dry and a refill. After opening it up, water flow miraculously started to work again.
    • Taking it apart is fun, but not needed. You can just wait 30 min, and it will work again. (Maybe some thermal fuse is reset then).
  2. AEG LM6000-U  Lavazza A Modo Mio Disassembly, Removing screws: 2 단계, 이미지 3개 중 1개 AEG LM6000-U  Lavazza A Modo Mio Disassembly, Removing screws: 2 단계, 이미지 3개 중 2개 AEG LM6000-U  Lavazza A Modo Mio Disassembly, Removing screws: 2 단계, 이미지 3개 중 3개
    • The machine mainly hangs together with plastic clips. There are 5 screws:
    • 1. Right under the powercable guide on the bottom.
    • 2+3 Under the Lavazza brand plates on either side.
    • 4+5 On the handle, under the plastic cover caps.
  3. AEG LM6000-U  Lavazza A Modo Mio Disassembly, Pictures: 3 단계, 이미지 1개 중 1개
    • Top picture: valve and water pump below that.
  4. AEG LM6000-U  Lavazza A Modo Mio Disassembly: 4 단계, 이미지 2개 중 1개 AEG LM6000-U  Lavazza A Modo Mio Disassembly: 4 단계, 이미지 2개 중 2개
    • Heating element
    • PCB has useful labels .
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Mark
회원 가입일: 09/05/18
492 평판
안내서 3개를 작성함
5가이드 댓글
Hi does anyone knows where is the thermoblock and if its easy to buy one on Modo Mio LM7000S-U (95007437700), Sometimes all lights flashing. I have to turn machine off and on again and if I am lucky it will work. AEG asked for £165 to repair it. Well I can buy a new one with thar money.
Manos - 답글
Hi Manos, did find a solution to your problem? I have the same issue and have bought a new machine but hoping to bring the old one back alive one day.
My understanding is that the thermoblock comes as part of the 'Brewing Unit' spare part purchasable from Electrolux, however it is listed as £133
martin riddell - 답글
Hi Manos,
How do you know it is the thermoblock.
Just thinking aloud: a thermoblock does not like something that sometimes works and sometimes doesn't.
Mark - 답글
My machine leaks water how do I get into it and is it an easy repair it the LM7000-U MODEL
Shaun - 답글
Is there a problem with newer batches of pods? I am seeing an increasing number where the coloured side of the pods is bending in so the machine can’t make proper holes - the resulting increased pressure makes its own hole, on the edge of the surface where the large holes should be, and coffee and grounds pour through this new hole.
Is it possible to post a picture on here?
Andrew Brown - 답글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 45
지난 30일: 197
전체 시간: 6,800
