주요 콘텐츠로 건너뛰기
AEG Lavamat L14850 washer dryer Inlet valve Replacement
필요한 것
  1. AEG Lavamat L14850 washer dryer Inlet valve Replacement, This is the beast: 1 단계, 이미지 1/1
    • Starting point: The washing machine pulled out of its cave, unplugged and disconnected from water and electricity.
  2. AEG Lavamat L14850 washer dryer Inlet valve Replacement, Empty away any excess water: 2 단계, 이미지 1/2 AEG Lavamat L14850 washer dryer Inlet valve Replacement, Empty away any excess water: 2 단계, 이미지 2/2
    • The washing machine may be full of water if the valve is faulty and therefore left slightly open.
    • There is a panel on the bottom right of the front of the washing machine. This contains the filters and emergency outlets. Open it forwards, and remove it.
    • Do _not_ unscrew the large valve to the left unless you are sure the machine is empty. You may be rewarded with several gallons of water pouring out. Instead, pull out the emergency outlet hose located to the top right, put it in a bucket, and pull out the tab controlling the water flow. Empty the bucket as necessary until all the water is gone.
    • Once all the water has been emptied, you can open the large valve, and catch the rest of the water in a towel.
  3. AEG Lavamat L14850 washer dryer Inlet valve Replacement, Remove top lid: 3 단계, 이미지 1/2 AEG Lavamat L14850 washer dryer Inlet valve Replacement, Remove top lid: 3 단계, 이미지 2/2
    • The top lid is held in place with two screws at the back as indicated. Remove these, and lift the lid off
  4. AEG Lavamat L14850 washer dryer Inlet valve Replacement, Locate the valve: 4 단계, 이미지 1/3 AEG Lavamat L14850 washer dryer Inlet valve Replacement, Locate the valve: 4 단계, 이미지 2/3 AEG Lavamat L14850 washer dryer Inlet valve Replacement, Locate the valve: 4 단계, 이미지 3/3
    • The valve is located at the rear of the washing machine, near the water inlet point to the washing machine. In fact, it is part of it.
    • The valve has several hoses connected to it, and electrical connectors as well. Take pictures from all angles to capture which connectors and which hoses go where.
  5. AEG Lavamat L14850 washer dryer Inlet valve Replacement, Disconnect the valve: 5 단계, 이미지 1/3 AEG Lavamat L14850 washer dryer Inlet valve Replacement, Disconnect the valve: 5 단계, 이미지 2/3 AEG Lavamat L14850 washer dryer Inlet valve Replacement, Disconnect the valve: 5 단계, 이미지 3/3
    • Disconnect all wires
    • Remove all the hoses connected to the valve
    • Remove the two screws that hold it on the rear panel
    • Lift the valve out
  6. AEG Lavamat L14850 washer dryer Inlet valve Replacement, The valve is out: 6 단계, 이미지 1/2 AEG Lavamat L14850 washer dryer Inlet valve Replacement, The valve is out: 6 단계, 이미지 2/2
    • Two pictures showing the washing machine without the valve, and the valve placed alongside the replacement unit
  7. AEG Lavamat L14850 washer dryer Inlet valve Replacement, Mount the new valve: 7 단계, 이미지 1/2 AEG Lavamat L14850 washer dryer Inlet valve Replacement, Mount the new valve: 7 단계, 이미지 2/2
    • Do all the earlier steps in reverse:
    • Attach hoses
    • Attach connectors (you *did* photograph them thoroughly, didn't you??)
    • Attach the valve to the rear panel
    • Reassemble the emergency valves and filters at the front
    • Attach the top lid with the two screws
  8. AEG Lavamat L14850 washer dryer Inlet valve Replacement, Re-connect the washing machine to inlet and outlet hoses: 8 단계, 이미지 1/1
    • Connect the inlet pipe
    • Connect the outlet pipe
    • Connect the electricity supply
    • Run a small program to test it works
    • Our washing machine is as good as new.
    • There is no flooding.
    • Bonus: The conditioner dispenser hadn't worked properly for ages. It now does! :-)
결론
Lars Erlandsen
회원 가입일: 04/17/18
1,313 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 26
전체 시간: 2,233
