주요 콘텐츠로 건너뛰기
AFK Toaster 70327 Electromagnet Replacement
필요한 것
  1. AFK Toaster 70327 Electromagnet Replacement, Removing the Side Panel: 1 단계, 이미지 1/3 AFK Toaster 70327 Electromagnet Replacement, Removing the Side Panel: 1 단계, 이미지 2/3 AFK Toaster 70327 Electromagnet Replacement, Removing the Side Panel: 1 단계, 이미지 3/3
    • Make sure to unplug the toaster.
    • An electrical shock could occur if the toaster is not unplugged.
    • Remove any foreign objects that may be located inside the toaster. After all objects are removed, turn the toaster upside down.
    • Use a tri-wing screwdriver to remove the screws located on each corner.
  2. AFK Toaster 70327 Electromagnet Replacement, Removing the Side Panel (continued): 2 단계, 이미지 1/2 AFK Toaster 70327 Electromagnet Replacement, Removing the Side Panel (continued): 2 단계, 이미지 2/2
    • Remove the black casing by sliding it upwards.
  3. AFK Toaster 70327 Electromagnet Replacement, Adjusting the metal rods: 3 단계, 이미지 1/2 AFK Toaster 70327 Electromagnet Replacement, Adjusting the metal rods: 3 단계, 이미지 2/2
    • Using the needle nose pliers, bend the two metal strips so they are facing the same direction.
  4. AFK Toaster 70327 Electromagnet Replacement, Removing the Wireframes: 4 단계, 이미지 1/3 AFK Toaster 70327 Electromagnet Replacement, Removing the Wireframes: 4 단계, 이미지 2/3 AFK Toaster 70327 Electromagnet Replacement, Removing the Wireframes: 4 단계, 이미지 3/3
    • Remove the two wire frames located on top of the toaster.
  5. AFK Toaster 70327 Electromagnet Replacement, Removing the metal rod: 5 단계, 이미지 1/2 AFK Toaster 70327 Electromagnet Replacement, Removing the metal rod: 5 단계, 이미지 2/2
    • Using the tweezers, pull out the long metal rod between the black casing and the metal component.
    • To reach the rod, make sure that the black casing and the metal are pushed away from each other enough to insert the forceps.
  6. AFK Toaster 70327 Electromagnet Replacement, Removing the coil spring: 6 단계, 이미지 1/2 AFK Toaster 70327 Electromagnet Replacement, Removing the coil spring: 6 단계, 이미지 2/2
    • While pushing the casing and metal away from each other, bend the two metal strips which are contained by the platform outwards.
    • Once the spring is loose, remove it using the needle nose pliers.
  7. AFK Toaster 70327 Electromagnet Replacement: 7 단계, 이미지 1/1
    • After removing the spring, remove the casing from the metal .
    • Using a Phillips screwdriver, remove the final screw.
  8. AFK Toaster 70327 Electromagnet Replacement, Disconnecting the old transformer: 8 단계, 이미지 1/3 AFK Toaster 70327 Electromagnet Replacement, Disconnecting the old transformer: 8 단계, 이미지 2/3 AFK Toaster 70327 Electromagnet Replacement, Disconnecting the old transformer: 8 단계, 이미지 3/3
    • Now that the electronic parts are clearly visible and easy to reach, the connections to the electromagnet can be unsoldered. Initially, only unsolder one of them.
    • With a testmeter on the resistance or Ω range, touch the two probes together and ensure the meter reads zero. Now touch one testmeter probe on the end of the now free electromagnet wire and the other on the other wire still soldered to the circuit board.
    • If you get infinite resistance then the electromagnet is faulty. Unsolder the other wire, remove the electromagnet by removing 2 screws, and replace.
    • If the electromagnet shows a resistance of a few hundred ohms then the fault lies elsewhere. Check the circuit board for any obviously overheated components, and if you are able, check there is a good connection to the circuit board from a tap on the element which taps off a small fraction of the mains voltage.
    • DO NOT attempt to test the toaster whilst dismantled as this would constitute a serious electric shock hazard.
    • Follow the instructions on properly using a soldering iron. Failing to do so can result in injury.
결론
lotte fontijne
회원 가입일: 03/08/17
101 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 26
전체 시간: 1,830
