주요 콘텐츠로 건너뛰기
AKASO KingPad A90 Battery Replacement
필요한 것
  1. AKASO KingPad A90 Battery Replacement, Battery: 1 단계, 이미지 1/3 AKASO KingPad A90 Battery Replacement, Battery: 1 단계, 이미지 2/3 AKASO KingPad A90 Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Remove screws.
    • Insert spudger tool on the middle of the left side, between the white and black plastic.
    • Slide in a plastic opening tool and use it to further pull the back off.
    • Work your way around the edge of the tablet with the plastic opening tool and insert more as needed.
    • Pull off the back cover.
  2. AKASO KingPad A90 Battery Replacement: 2 단계, 이미지 1/3 AKASO KingPad A90 Battery Replacement: 2 단계, 이미지 2/3 AKASO KingPad A90 Battery Replacement: 2 단계, 이미지 3/3
    • Using the black plastic spudger tool, insert it under a corner of the battery.
    • Work your way around the edges to pry the battery and loosen it from the adhesive.
    • Remove the battery.
  3. AKASO KingPad A90 Battery Replacement: 3 단계, 이미지 1/3 AKASO KingPad A90 Battery Replacement: 3 단계, 이미지 2/3 AKASO KingPad A90 Battery Replacement: 3 단계, 이미지 3/3
    • Locate the battery unit solder points and note where it is attached to the motherboard.
    • Plug in your soldering iron/pen and wait the required amount of time to heat up.
    • Be careful with the iron as the tip is very hot and it could burn you or the tablet
    • Apply a small amount of pressure with the iron on the solder points until the joints come loose and the wires move freely away from the board
    • Remove the battery unit
  4. AKASO KingPad A90 Battery Replacement: 4 단계, 이미지 1/3 AKASO KingPad A90 Battery Replacement: 4 단계, 이미지 2/3 AKASO KingPad A90 Battery Replacement: 4 단계, 이미지 3/3
    • Locate the red and black wire ends of your new battery
    • Take your solder out and place it on the point with the wire
    • Use the iron/pen to slowly melt a small piece of solder onto the point and let it solidify.
    • Be careful not to use too much solder as a large blob could result in a short on your device
    • Repeat this step for the other point
  5. AKASO KingPad A90 Battery Replacement: 5 단계, 이미지 1/3 AKASO KingPad A90 Battery Replacement: 5 단계, 이미지 2/3 AKASO KingPad A90 Battery Replacement: 5 단계, 이미지 3/3
    • Replace the back cover with the new part in place.
    • Gently press the speaker into place.
    • Don't let the volume rocker unit fall out of place.
    • Replace the screws.
결승점
다른 5명이 해당 안내서를 완성하였습니다.
Daniel Garcia
회원 가입일: 03/24/15
179 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 4-6, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-6, Vijaybhaskar Spring 2015 회원
UMASSD-VIJAYBHASKAR-S15S4G6
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 9
전체 시간: 1,962
