주요 콘텐츠로 건너뛰기
AKASO KingPad A90 Rear Speaker Replacement
필요한 것
  1. AKASO KingPad A90 Rear Speaker Replacement, Rear Speaker: 1 단계, 이미지 1/3 AKASO KingPad A90 Rear Speaker Replacement, Rear Speaker: 1 단계, 이미지 2/3 AKASO KingPad A90 Rear Speaker Replacement, Rear Speaker: 1 단계, 이미지 3/3
    • Remove screws.
    • Insert spudger tool on the middle of the left side, between the white and black plastic.
    • Slide in a plastic opening tool and use it to further pull the back off.
    • Work your way around the edge of the tablet with the plastic opening tool and insert more as needed.
    • Pull off the back cover.
  2. AKASO KingPad A90 Rear Speaker Replacement: 2 단계, 이미지 1/3 AKASO KingPad A90 Rear Speaker Replacement: 2 단계, 이미지 2/3 AKASO KingPad A90 Rear Speaker Replacement: 2 단계, 이미지 3/3
    • Plug in soldering iron and let it warm up for ten minutes.
    • Locate the speaker solder points and note where it is attached to the motherboard.
    • Solder the old speaker out of its mark. (Touch the tip of the solder iron to the soldering point).
  3. AKASO KingPad A90 Rear Speaker Replacement: 3 단계, 이미지 1/3 AKASO KingPad A90 Rear Speaker Replacement: 3 단계, 이미지 2/3 AKASO KingPad A90 Rear Speaker Replacement: 3 단계, 이미지 3/3
    • Solder the new speaker onto the points where the old speaker was.
  4. AKASO KingPad A90 Rear Speaker Replacement: 4 단계, 이미지 1/3 AKASO KingPad A90 Rear Speaker Replacement: 4 단계, 이미지 2/3 AKASO KingPad A90 Rear Speaker Replacement: 4 단계, 이미지 3/3
    • Replace the back cover with the new rear speaker unit in place.
    • Gently press the speaker into place.
    • Don't let the volume rocker unit fall out of place.
    • Replace the screws.
결승점
camchristo
회원 가입일: 03/24/15
71 평판
안내서 1개 작성함
UMass Dartmouth, Team 4-6, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-6, Vijaybhaskar Spring 2015 회원
UMASSD-VIJAYBHASKAR-S15S4G6
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 382
