주요 콘텐츠로 건너뛰기
AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement
필요한 것
  1. AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement, Volume Rocker/Power Button Unit: 1 단계, 이미지 1/3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement, Volume Rocker/Power Button Unit: 1 단계, 이미지 2/3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement, Volume Rocker/Power Button Unit: 1 단계, 이미지 3/3
    • Remove screws
    • Insert spudger tool on the middle of the left side, between the white and black plastic
    • Slide in a plastic opening tool and use it to further pull the back off.
    • Work your way around the edge of the tablet with the plastic opening tool and insert more as needed
    • Pull off the back cover
  2. AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: 2 단계, 이미지 1/3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: 2 단계, 이미지 2/3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: 2 단계, 이미지 3/3
    • Remove the broken volume rocker/power button unit.
    • Place the new part into the empty slot.
  3. AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: 3 단계, 이미지 1/3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: 3 단계, 이미지 2/3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: 3 단계, 이미지 3/3
    • Gently press the speaker into place.
    • Replace the back cover with the new part in place.
    • Be careful to not let the volume rocker unit fall out of place.
    • Replace the screws.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Miles
회원 가입일: 03/24/15
260 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 4-6, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-6, Vijaybhaskar Spring 2015 회원
UMASSD-VIJAYBHASKAR-S15S4G6
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 519
